Steel or Aluminum?
Location: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Steel or Aluminum?
Well I bought this BLITZ BOV right? It comes with a Steel flange with it, now, I don't know if my charger pipe will be aluminum or steel, I imagine that I can choose when I get to the shop cuase they said they could make one for me.
now I don't feel like paying a extra to buy a Aluminum flange but.. if I do have to get a steel charger pipe.. is it bad?? Or does it make no real big difference??
I mean.. as long as both are strong and will work, I dont' care. But if steel like to crack and blow up and melt and cuase radiation and stuff... I will get another aluminum flange.
I need to know soon.. thanks...
Re: Steel or Aluminum? (dustin)
Cool thanks.. ARe steels simply just.... heavier and that's it? Or is there more to it than that?
Re: Steel or Aluminum? (Snafu-Si)
steel is really not that much haeavier, its a stregth to weight ratio thing, you can use the same diameter Al tubing and it will be lighter than steel, also mils steel will have a tendency to rust on the inside from all the compressed turbo air condensing water vapour into droplets / humid or not. Aluminum requires an expensive welding setup. I use stainless 16 gauge, I like the smooth surface and the great welds.
Re: Steel or Aluminum? (rtype11)
stainless is the nice stuff just little expensive but well worth it compared to the mild stuff. Aluminum is nice if oyu got someone to weld it for your for cheap. I can weld it but it takes so much effort to do it cleanly. and stainless i can make it look really really nice.l
not trying to start an argument... but it has been done before... it wierd how u have to have weld it... i heard of how too... but i dont know if its really widely known or a secret though
Re: Steel or Aluminum? (ek9t)
they are unlike, steel is ferrous - iron containing, Al is non ferrous, all they have alike is low carbon, if you do get them joined, it will not be a homogeneous bond. it will be mechanical. good luck doing things this way.
I'll just find out what Tom Payn can do..or kevin vankoopa can do.
New User
Re: Steel or Aluminum? (dbman96)
Like.. what?? Like.. Glue? paste? Duct tape??
AzntaggeR
Welding / Fabrication
03-21-2005 08:55 PM
