whats a better turbo motor B16A or B18A/B?
Re: whats a better turbo motor B16A or B18A/B? (TheSwift1)
ok, but that wasnt one of the options. plus im not sure if i would trust that engine to rev high and boost...
Re: whats a better turbo motor B16A or B18A/B? (turbohf)
I would definetly take the B18. I own both b18 and b16 and I LOVE my b18 much more then my b16.
Re: whats a better turbo motor B16A or B18A/B? (dustin)
umm, again not one of the choices. i already had a D15 and took it out, its for sale btw $20 pick up only ...
New User
New User
the b16 is an amazing motor, i would go with it. beats the hell out of the b18
its stronger and it has a better bore to stroke ratio
b16 all the way
b16 all the way
Re: whats a better turbo motor B16A or B18A/B? (fuguman)
its the stock HF block, i just want it out of my yard.
most your opinions say NOTHING about it being a TURBO motor. the just say it revs higher etc. anyway im leaning towards the B18A/B or if i can get the money a B20B/Z...
The b18 will hold more boost with stock internals. The compression of the b16a in stock form limits the amount of boost it can hold. In my opinion I would buy the motor that is cheaper and then build it accordingly.
Re: whats a better turbo motor B16A or B18A/B? (Liltrix)
well the b16 might have more hp then the 18 but it moves less air and it revs very high with the help of vtec in a way to aquire more hp from its low torque line. I would go with a B18b because it flows allot more air to move that turbo. It might not rev high but who cares when you have a nice torque line = ). plus the b18 has lower compression perfect for boost and the rods are monsters for a honda.
Re: whats a better turbo motor B16A or B18A/B? (91civic)
91civic, thanks thats the kind of anwer i was looking for, infomitive...
kamira, very good pionts...
im thinking i should build this motor for boost right off the bat, like 20psi
b16 all the way
b16 all the way
Re: whats a better turbo motor B16A or B18A/B? (kamira)
b16s still have an awesome torque line!!!!!!!!!!!!!!!!!
its up to you.at first ill be 1.6,,,but i will be upgrading to 1.8 for more torque.
