Safe to hold boost??
Old Apr 30, 2002 | 08:44 PM
R-1303's Avatar
Default Safe to hold boost??
I have a Type-R and going to bolt on my drag 3 kit...do you think is safe to boost
6-7 psi and rev it up to 8400rpms on a complete stock ITR motor??
Old Apr 30, 2002 | 08:45 PM
AlphaKennyWun's Avatar
Default Re: Safe to hold boost?? (R-1303)
at least let the car warm up first
Old Apr 30, 2002 | 08:48 PM
well you have high compression to worry about so keep it at 6-7 psi no more without lower compression. Should feel a nice kick in the *** with that psi.
EDIT: ITR valve train is stronger than GSR so should be fine. Stock GSR valvetrains are also strong.
[Modified by SO3Burner, 5:49 AM 5/1/2002]
Old Apr 30, 2002 | 08:54 PM
Muckman's Avatar
Moderator in Chief
Not that it matters if you already have the Drag 3 kit - but if your only gonna be using 6-7psi then you could have went with a smaller turbo kit and had quicker spool time and still run 6-7psi
Old Apr 30, 2002 | 09:27 PM
B20C5 Turbo's Avatar
New User
Listen very closely for the "marbles in a can" signs of detonation. Depending on your altitude/octane/ambient temperature, you may or may not have problems at 7psi. If you plan on doing nothing further, you should still consider the J&S Ultra Safeguard for security and peace of mind.
P.S. It's not going to be the 8400 rpm with boost that kills you, it's the fueling and timing change at VTEC. Pay VERY close attention to how things sound around the crossover point. Good Luck.
[Modified by B20C5 Turbo, 11:30 PM 4/30/2002]
Old May 1, 2002 | 02:24 AM
MiraiZ's Avatar
Default Re: Safe to hold boost?? (B20C5 Turbo)
hmmm.....I'd lower compression a bit....at least...don't do ghetto home depot installs on an ITR...
Old May 1, 2002 | 04:52 AM
PrecisionH23a's Avatar
Default Re: Safe to hold boost?? (MiraiZ)
d i t t o
Old May 1, 2002 | 10:12 AM
R-1303's Avatar
Default Re: Safe to hold boost?? (GudeH23a)
Thanks a lot guys..i'll watch for signs of detonation when vtech starts to cross over...and the J and S safetgaurd is not going to be on my list because i plan to buy a hondata in the near future..planning to have the engine full built and balanced by the end of summer..but tunning is key so i got to take it easy for now..if you guys have any other suggestion please let me know..like guages to monitor engine efficientcy.. i have A/f and boost..but not egt..
laocivic
Oct 24, 2007 07:25 AM
rsx13k
May 25, 2007 12:38 PM
xstalkrx
May 26, 2003 08:08 PM
sunny79
Oct 20, 2002 02:58 PM
X2BOARD
Apr 18, 2002 10:51 AM
