Need help asap
Old May 1, 2002 | 03:37 AM
Wicked Sol's Avatar
New User
Default Need help asap
Is it safe to boost gsr motor @ 15 psi thats been bored 20 over but with no sleeves or block gaurd? Assuming it has all the supporting mods like 9-1 comp, rods and fuel.
An help is really appreciated
Old May 1, 2002 | 04:46 AM
92JDMSiR's Avatar
Default Re: Need help asap (Justa4)
personally I wouldn't do it unless I was using hondata. I've seen more then 15 psi on an un-sleeved block. I would definitely consider putting a block guard for the extra insurance.
when you run that much boost and your not well tuned tiny little problems turn into blown motors.
Old May 1, 2002 | 04:49 AM
b18bturbo's Avatar
Default Re: Need help asap (92JDMSiR)
Very true... I wouldnt risk destroying your motor at 15psi by little detonation.
Old May 1, 2002 | 04:53 AM
PrecisionH23a's Avatar
no it is not safe. i recommend resleeving the block and running a block guard, or get the darton sleeve kit that will convert your block into a closed deck one.
Old May 1, 2002 | 05:12 AM
rtype11's Avatar
I would run 15 psi on an LS not a GSR, simple cost of replacement issue, you can have the best tuned motor in the world, one tank of bad tank of gas or voltage fluctuations can change all that. (this is only in ref to stock cylinder
b18-crx
Aug 3, 2009 01:37 PM
red00si12
May 28, 2007 03:18 PM
Irishweird00
Feb 11, 2003 10:45 AM
94TealGSR
Feb 8, 2003 08:39 AM
sleepercivic
Sep 11, 2002 08:12 AM
