WHAT NEXT?
Old Apr 30, 2002 | 03:14 PM
Teg4e's Avatar
Default WHAT NEXT?
Well, i haven't installed my turbo yet, but I'm already thinking what I should add next. My car's just a daily driver, not something that i would autocross or make into any kind of serious drag car. But i think i may want something slightly faster than where it will be with the kit + exhaust. My car has 0 mods other than the ones listed in my sig. Thanks!
Old Apr 30, 2002 | 03:31 PM
Teen Heartthrob's Avatar
Default Re: WHAT NEXT? (Teg4e)
suspension, anyone?
Old Apr 30, 2002 | 03:36 PM
voltronR34's Avatar
Yeah, a nice set of dampers to help you put the power down.
Old Apr 30, 2002 | 03:45 PM
dbman96's Avatar
New User
As far as chassis upgrades, I would upgrade a turbo car in this order:
GOOD tires
Brakes - at least upgrade to Type-R size fronts with good pads
Decent shocks (Koni, KYB, etc)
19-22mm rear sway bar
Coilovers or lowering springs depending on how much you want to drop your car
Old Apr 30, 2002 | 04:12 PM
DIRep972's Avatar
Smarter than you
Default Re: WHAT NEXT? (dbman96)
GOOD tires
what he said.. tires are a MUST, definitly get some good brakes if u race alot, if the car is not lowered, i would lower it with a good shock/spring set up.. THen if u need more power, look into boost controller, oh youll need a good clutch, and then maybe a fuel system..
[Modified by DIRep972, 1:13 AM 5/1/2002]
Old Apr 30, 2002 | 04:19 PM
2K_TEG's Avatar
Default Re: WHAT NEXT? (DIRep972)
GOOD tires
this could go on forever....
Old Apr 30, 2002 | 05:15 PM
Teg4e's Avatar
Default Re: WHAT NEXT? (2K_TEG)
Ok, so suspension things are in order..... i have the stock 14" alloys on my 98 LS, which have Bridgestone Potenza 950's on them. They're supposed to have good dry traction but they still slip. I can't imagine what it's gonna be like when I add another 100HP into them.... the tires are 195/60/14. is it even possible to have good traction on a tire of this size on a FWD car? Does upgrading to a good set of 16x7 make a significant difference? i've been looking and those SSR's.....
Also, thanks for the suggestions on suspension...what brands should i look at/avoid?
big-cat
Suspension & Brakes
Jul 30, 2009 08:13 PM
DJThomas1189
Suspension & Brakes
Feb 15, 2007 03:20 PM
EsCo_EsCo
Suspension & Brakes
Aug 20, 2006 02:15 AM
flipwhip
Jun 2, 2006 10:54 AM
Stunna BEN
Dec 3, 2001 04:12 PM
