what size pistons?
Old Apr 28, 2002 | 12:17 PM
98civicEX's Avatar
Default what size pistons?
i'm getting some 9:1 JE pistons and was curious what you guys thought would be a good size...they're going in my D16y8. yes, that wasn't a type-o...in my D16y8...., i'm swapping this TD04 and replacing w/ a drag, and will hopefully be boosing in the low 20 psi range....just curoius to what you guys thought would be a good size...
Old Apr 28, 2002 | 07:29 PM
98civicEX's Avatar
Default Re: what size pistons? (98civicEX)
ttt
Old Apr 28, 2002 | 08:28 PM
VTC_CiViC's Avatar
20psi?? Umm.. I'm guessing you're sleeving this block right? LOL, I should hope so! What do you mean by what size piston? You mean what bore? I'm personally going for a 78mm bore with GE sleeves, gives me about a 1740cc displacement vs. 1590cc stock.
Old Apr 28, 2002 | 08:37 PM
D-Man's Avatar
Default Re: what size pistons? (VTC_CiViC)
When i had my block sleeved i didnt oversize it,went with the stock size cause i figure the thicker the cylinder walls the stronger they are and the more boost they could handle.
raverx3m
Jun 10, 2014 10:55 AM
dritan
Jan 7, 2011 07:18 AM
thollis97
Jan 22, 2007 05:22 PM
Civic Racer X 7
16
Nov 6, 2005 04:11 AM
lsvtecrocket
Dec 24, 2003 10:15 PM
