Stage1 cams ok with turbo?
I have Stage1 Crower cams in my car but am going turbo. Everything has been purchased already. Can those of you with better technical understanding give me your opinion as to what would be better....stock or crower cams for turbo. First is the specs for the Crower cams and the second is for a stock Prelude (SH).
Duration Duration @ .050” Gross Lift w/1.55
Int –282 Int – 239 Int - .457
Exh – 279 Exh – 230 Exh - .426
Int – 275 Int – 225 Int - .448
Exh – 275 Exh - 227 Exh - .415
I really don't want to go through the hassle of swapping the cams if I really don't have to. I spoke with Brian from Crower and he said it should be fine. I just wanted a second opinion. I do have Skunk2 cam gears to adjust the overlap a bit.
I plan on raising the rev limit to 8000 since these cams make power to 7800rpm (using aem ems). I have springs and retainers so the 8000rpm limit should be fine. Any opinions would be greatly appreciated.
[Modified by Anubyss, 12:47 PM 4/30/2002]
