bad fmu
Old Jul 3, 2002 | 08:29 PM
sunscreen's Avatar
Default bad fmu
is there a way to find out if your fmu is bad. i opened it up and it looks good it wasnt dirty in there. but my car seems to run lean i also have a inline pump
Old Jul 3, 2002 | 08:40 PM
DragII's Avatar
25 Year Member
Default Re: bad fmu (sunscreen)
what ratio FMU are you running, how much boost, which injectors, what turbo kit, do you have a FPR gauge?
Old Jul 3, 2002 | 08:48 PM
sunscreen's Avatar
Default Re: bad fmu (DragIIDigital)
12:1 fmu, drag kit on a d16z6 with 5lbs, stock injectors, msd ignition with plugs gapped to .032, and stock fpr. any opinions on why i am running lean
Old Jul 3, 2002 | 08:56 PM
sushibug's Avatar
are you positive the inline fuel pump is even working? just fyi, i had the same setup and at 5psi w/o the inline i leaned out. it was fine at 4psi though. i ran 10-12psi w/ a 12:1 fmu and inline pump w/o leaning out.
Old Jul 3, 2002 | 08:57 PM
DragII's Avatar
25 Year Member
is your inline pump working properly?
It's possible that the fmu got stuck, it's been known to happen. I'm not sure how you can check it w/ out a fpr gauge though.
I ran rich up to 10psi on my old DRAG set up.
civic dx
Nov 27, 2004 03:08 PM
SIK IN DA HED
Nov 13, 2003 08:53 AM
_Endless_
Sep 2, 2002 01:28 AM
Hybrid
Aug 9, 2002 03:14 PM
bottlefedb18c1
Aug 1, 2002 09:35 AM
