Cheapo BOV for recirc setup..suggestions?
Old Jul 4, 2002 | 08:18 AM
Smashback's Avatar
Default Cheapo BOV for recirc setup..suggestions?
I was considering Greddy but I'm just to cheap. What kind of decent OEM BOVs are out there guys? I'm switching from a TurboXS. Going to go with a recirculating setup to keep things more on the downlow.
I've seen the Bosch from several turbo cars are popular. Any others out there?
Old Jul 4, 2002 | 09:15 AM
Smashback's Avatar
Default Re: Cheapo BOV for recirc setup..suggestions? (mplex2000)
ttt
Old Jul 4, 2002 | 09:18 AM
CovertFI's Avatar
bosh
they came on the 900 saab turbos. you can find them used for like 25 bucks. just search on the internet and you can find it.
Old Jul 4, 2002 | 09:50 AM
Jared's Avatar
Default Re: Cheapo BOV for recirc setup..suggestions? (CovertFI)
The 1st gen eclipse turbo bovs work well too. I got mine for $25 used.
Old Jul 4, 2002 | 10:24 AM
paulzy's Avatar
Default Re: Cheapo BOV for recirc setup..suggestions? (Jared)
I used the turboXS type H Bypass version...works wonders
Old Jul 4, 2002 | 10:36 AM
93LSivic's Avatar
Thats what I use.
By the way, if you want quiet your BOV then just plum it back into the intake tract. It'll also keep the turbo spooled between shifts!
Old Jul 4, 2002 | 11:57 AM
ion_four's Avatar
Default Re: Cheapo BOV for recirc setup..suggestions? (93LSivic)
How does a recirculation system work? Does anyone have pics?
Old Jul 4, 2002 | 03:05 PM
Smashback's Avatar
Default Re: Cheapo BOV for recirc setup..suggestions? (ion_four)
Instead of venting the air to atmosphere, you need a BOV with an "output flange" so you can route a hose from it back into the turbo intake. This way you shouldn't hear the pssshhhh.
Old Jul 4, 2002 | 04:06 PM
ion_four's Avatar
OHhhh...so, you have a hose going from that to in between the air filter and compressor?
Old Jul 4, 2002 | 08:45 PM
Smashback's Avatar
Exactly. That's not the way mine is now, but with an OEM BOV from a factory turbo car or an aftermarket that has a flange on it will work that way if you want it to. For those interested, I have found a couple of really cool aftermarket Bosch replacements. Not nearly as cheap, but very nice.
http://www.stratmosphere.com/hyperboost.htm
http://www.stratmosphere.com/forge_valves.htm
Jose-aka-Pedro
Jul 26, 2005 05:52 PM
ddua
Oct 1, 2003 06:59 AM
egsick6
May 30, 2002 09:52 PM
93LSivic
Aug 16, 2001 10:46 AM
