Relaibility of DRAG 3 fuel pump??
They are reliable and work fine... direct substitute for bosch pumps. Some people mistakenly believe that they don't need the DRAG/airtex pump cuz they have an intank, but as as has been discussed here a million times if you are using an fmu, you must use an inline pump...
****... i have a walbro pump and a 12:1 fmu... i thought i was fine (2nd day boosting (rarely))... i should definitely hook the intank up as well?
so you should use the intank and inline at the same time???
what if your running say a piggy back system like greddy or AEM would you need to run an inline???
no as long as you have bigger injectors
it's not about the pressure i wanna know how much fuel can it flow at those elevated pressures
example 50gallons at 90psi walbro pump
KevronsEG
Jul 31, 2002 07:09 PM
