update on my engine teardown
Old Jul 3, 2002 | 02:36 PM
GruvyTune's Avatar
New User
Default update on my engine teardown
finally got my engine completely torn down. First time for me! anyway, as expected, blown ringlands (both of them) on my 1 and 4 pistons. cylinders look perfect. got JE 9:1 0.20 over pistons to go in along with Eagle rods and ARP headstuds. Machinist gets the block next week!
Now I wish I had the funds and the time to sleeve the thing. Oh well, 1 Bar will have to suffice.
Old Jul 3, 2002 | 02:39 PM
dustin's Avatar
Default Re: update on my engine teardown (GruvyTune)
Sucks about the motor, but it will be back better than ever
Old Jul 3, 2002 | 04:00 PM
CovertFI's Avatar
can you take a pic of the broken ring lands. dont know what that looks like.
Old Jul 3, 2002 | 05:28 PM
GruvyTune's Avatar
New User
Default Re: update on my engine teardown (CovertFI)
don't have a digi cam right now. basically there are cracks splitting the ringlands in two!
Old Jul 3, 2002 | 05:30 PM
CovertFI's Avatar
is that the part between the rings or the top of the piston and the ring.
Old Jul 3, 2002 | 05:35 PM
GruvyTune's Avatar
New User
its the part between the rings, on one piston it broke there and on the lands between the oil seal and the lower ring!
Old Jul 3, 2002 | 06:23 PM
b18bvudoo's Avatar
New User
how did u bust em? thot yor car was tuned properly. what boost level were u at?
Old Jul 3, 2002 | 06:40 PM
GruvyTune's Avatar
New User
Default Re: update on my engine teardown (vudoo666)
hmmm. well I gutted my cat and ran a test pipe through it. My boost controller was set for a particular duty cycle and bam, I boosted past my set point and my hondata maps were not set to go that high. I didn't notice anything bad happen just that i had white smoke out my breather. guess I must have detonated or the stock ringlands could not take 12 psi? I wonder how far I can push the stock sleeves with forged internal?? I think i'm gonna be a bit careful at least till I have the time and money to start work on an all out sleeved/built engine
Old Jul 3, 2002 | 06:41 PM
dustin's Avatar
12psi on 10:1 compression w/ pump gas is asking for trouble anyways
Old Jul 3, 2002 | 06:46 PM
earl's Avatar
Probably hurt the ring lands by running it way too lean. Thats where it shows up first. You can't tell you're doing it while it's happening. It sucks but part of the game. Cyinders can look unhurt but they may be balooned out of round.
Old Jul 3, 2002 | 06:54 PM
GruvyTune's Avatar
New User
Default Re: update on my engine teardown (earl)
don't think i was running lean up to about 11.5 psi. a:f was about 12:1 to there. after that, dont know what happened. i normally didnt' run over 10.5psi. anyway, new pistons will be going in after boring block to 81.5. I hope the cylinders check out ok!
Old Jul 3, 2002 | 11:32 PM
VaporTrail's Avatar
New User
Hey man, you know Hondata has a boost cut feature that can save your *** from that right? Of all the Hondata boosted cars that I've tuned, which currently that number is about 12, only one has blown - the one that requested I not put in a boost cut. Take a guess as to what happened....
Old Jul 4, 2002 | 05:36 AM
GruvyTune's Avatar
New User
Default Re: update on my engine teardown (VaporTrail)
John, I had that set to 11.2 psi. Doug said if it were to cut I would know it and that the MAP/Hondata read lower than most boost gauges. So I probably didn't cut with the Hondata. I really don't know what happened. Besides, hondata cuts fuel at that point which can lead to lean...detonation?
Old Jul 4, 2002 | 06:33 AM
downpipe's Avatar
the same thing happened to me back in november. cracked ringlands in #1 and #4. except mine was greddy and i think it was the fault of the blue box. what sucked for me is that my cylinders were quite scored up. well, it doens't totally suck because my block is on the way back from GE, should be here friday. but it sucks how long my car has been down for.
anyway, i think i'l be back ina ction in a month or so, ny the time i get everything else squared away.
good luck!
Old Jul 4, 2002 | 06:40 AM
DragII's Avatar
25 Year Member
no fuel = no combustion right?
Old Jul 4, 2002 | 10:20 AM
VaporTrail's Avatar
New User
its actually a pretty harsch boost cut, it's not like hitting the rev limiter, where you'd sit there and bounce off of it.
Old Jul 4, 2002 | 10:34 AM
Liltrix's Avatar
It is not a good idea to cut fuel!, maybe the ignition, but definately not the fuel. No fuel leads to makes a lean situation even worse.
Old Jul 4, 2002 | 11:40 AM
earl's Avatar
.5 mm should clean it up fine.
jprelude92
Oct 28, 2009 01:41 PM
karmadhi
May 17, 2008 10:40 AM
SweepeR 7
Nov 8, 2003 08:41 AM
Greyout
Jul 11, 2003 01:02 PM
JDM EG2
Sep 10, 2002 04:42 PM
