quick question about the EMS
Old Jul 6, 2002 | 10:46 PM
tararan's Avatar
Default quick question about the EMS
i got a 00 honda civic EX.. been turbo for about 10K miles now... been boostin stock ever since... i was gonna go with the hondata 2B but now ive read more about the EMS, and its very tempting... mostly that it includes a boost controller and all the other good stuff.... and its also compatible with OBD II vehicles..
i only wanna boost up to 7-10 pounds.. just on my stock internals.. i was wondering if i have to change my injectors to a bigger size if i use the EMS... do i have to replace the fuel pump???? reading about the EMS plug and play gives me the idea that its just plug and play..
Old Jul 6, 2002 | 10:54 PM
Mike@Altered's Avatar
Default Re: quick question about the EMS (tararan)
You can use the EMS on a bone stock honda if you'd like, so you do not have to chance anything from your current set-up if you don't want to.
However, if your running that much boost right now w/ stock injectors I'm assuming your running an FMU. When you get the AEM EMS I'd trash the FMU and run larger injectors instead. The EMS will allow you to safely map your fuel curves for the larger injectors and you car will drive the same if not better than your car with the factory injectors!
Hope this helps,
Old Jul 6, 2002 | 11:29 PM
tararan's Avatar
Default Re: quick question about the EMS (Mike@Altered)
helps a lot.... thank you.. i got a vortech FMu right now... like i said im only boosting stock which is 5 lbs...
reason i wanna go with standalone is the reliability on it and less rtouble with other stuff (FMU, o2 sensor problem, etc)... 8 lbs may be even the max ill run on it for a while.. im not into too much power...
Old Jul 7, 2002 | 11:22 AM
PyroVTEC's Avatar
New User
Heya tararan... pyro again...
Yes you'll have to get a bigger fuel pump in addition to the larger injectors as well. The fuel pump and larger injectors go hand-in-hand.
Other neat features I found in my AEM EMS is the secondary rev limiter... I haven't installed my EMS yet, but how it's supposed to work is like the hondata 3b. You can set a preset lower rev limit when you have the clutch depressed, to say 4000rpm. When you let the clutch out, the ECU will use the higher rev limiter (e.g.: the stock 6900rpm rev limiter). It's useful if you want to launch consistently at dragstrips. Turbo timer function is also built-in as well as an expandable boost controller as well. Just a few perks of the EMS.
Old Jul 7, 2002 | 12:11 PM
tararan's Avatar
Default Re: quick question about the EMS (PyroVTEC)
oh shoot.. definitely goin this route... thanks again for your help bro.... you can ignore my last IMed to you....
Old Jul 7, 2002 | 12:14 PM
SlowB16's Avatar
Ok stupid question, but is the EMS plug and play with OBD1?
Old Jul 7, 2002 | 12:22 PM
b18bturbo's Avatar
Default Re: quick question about the EMS (SlowB16)
yes .. it is
Old Jul 7, 2002 | 12:29 PM
senpai's Avatar
damn! you're making me want to get one! stop it...
Old Jul 7, 2002 | 11:49 PM
PyroVTEC's Avatar
New User
Default Re: quick question about the EMS (maztur)
heheh...
From a bang for the buck perspective, it's like this...
OBD-0 car (i.e. pre-OBD): Zdyne
OBD-1 car: Hondata
OBD-2 car: AEM EMS
Old Jul 8, 2002 | 06:32 AM
KC GSR's Avatar
is the EMS pretty easy to tune or is it one of those deals where you spend 1600 dollars and no dyno shop knows what to do with it
Old Jul 8, 2002 | 06:38 AM
98Psi ITR's Avatar
Default Re: quick question about the EMS (KC GSR)
The best thing since sliced bread
Remember you'll need a solenoid still for boost control. You can set low and high boost for example. Yes you can also setup a 2 step.
Old Jul 8, 2002 | 07:07 AM
tararan's Avatar
Default Re: quick question about the EMS (98Psi ITR)
solenoid, huh??? damn, how much that thing cost? im planning on keeping my car really close to stock configuration as far as tuning goes... dont wanna get too complex.. just want to tune to run the car safely...
Old Jul 8, 2002 | 07:09 AM
b18bturbo's Avatar
the solonoid is like 15 dollar item from GM dealer .... it not expensive.
Old Jul 8, 2002 | 07:25 AM
98Psi ITR's Avatar
Default Re: quick question about the EMS (b18bturbo)
If you have EMS related questions or are looking for info on the EMS from AEM then please feel free to check out the forum at AEM's site. Tons of info.
Old Jul 8, 2002 | 11:21 AM
tararan's Avatar
thanks..
Old Jul 8, 2002 | 11:27 AM
SiRkid's Avatar
whats the part number?
Old Jul 8, 2002 | 06:57 PM
PyroVTEC's Avatar
New User
Default Re: quick question about the EMS (SiRkid)
P/Ns are also on the AEM website.
Masho
Honda Civic (2001 - 2005)
Dec 9, 2010 11:34 AM
StrangerWitCandy
Feb 2, 2005 04:12 PM
SweetChin
Mar 31, 2003 02:33 PM
Boltz
Dec 24, 2002 05:31 AM
LonelyDriver02
Jul 31, 2002 07:45 AM
