Resleeve Project
Old Jul 2, 2002 | 11:39 PM
B-Series Sol's Avatar
Default Resleeve Project
Planning on buying a 94 integra LS w/ lots of miles (as a way of saving $ for my turbo project, drag 3 turbo kit @ 9-10psi max)
In order to resleeve it the block has to be pulled, but while its out...
what else should I do to the block, and how much do these parts cost?
Old Jul 2, 2002 | 11:49 PM
PrecisionH23a's Avatar
Default Re: Resleeve Project (B-Series Sol)
resleeve block + copper o-ring $800-900
Je pistons + Crower rods $1100 (or you can get eagles, they are about half the price and just as durable)
crank rebalanced and polished - $ask machine shop
new main bearings and rod bearings -OEM honda - $80 for rods and i think $75-85 for main??
redeck block $20
new headgasket
ARP headstuds
also its a good idea to replace all the gaskets and oil seals.
thats all i can think of off the top of my head
Old Jul 3, 2002 | 02:30 AM
boostinb18's Avatar
Default Re: Resleeve Project (GudeH23a)
i didnt think resleeving was that expensive !!!
Old Jul 3, 2002 | 02:35 AM
DSF's Avatar
DSF
Default Re: Resleeve Project (boostinb18)
Turbo in general is expensive
Old Jul 3, 2002 | 06:40 AM
justagsr's Avatar
redeck block $20
new headgasket
ARP headstuds
All I can think of is replace your water and oil pump and beef up your clutch.
<-------doing all the above plus some right now. lol
Old Jul 3, 2002 | 10:14 AM
93LSivic's Avatar
IMO, you dont need to sleeve the block for a measly 9-10 psi of boost. I would say, take it to the machine shop, have them inspect the cylinder walls. If everything looks fine then have them hone it, reassemble with new rings, bearings. IF not, then bore it .20 over and buy some new pistons.
With the money you save, buy hondata or ems, some injectors, and gauges. You will be happy you did, and if you find a great tuner you should be able to run 15 psi on it with pump gas.
Then again, thats just me. If you have the money, then do the above with the GEM sleeves and whatnot. Basically you mentioned that your saving money--well, your not really saving money by completely building the bottom end.
[Modified by 93LSivic, 2:16 PM 7/3/2002]
Old Jul 3, 2002 | 09:01 PM
noel's Avatar
B Series Sol,
Dude that's exactly what I plan on doing. I've got 2500 bucks saved up right now for the integra. It'll probably have about 120k+ on it. I'm saving up for block resleeving, pistons, rods, bearings, all that good stuff. I'm also considering what type of headwork needs to be done to an engine of that age? I suppose if it looks? good and isn't in total despair when I get it all will work out well. Like the guys mentioned a new water pump is gonna be a must. I'm sure those little bastards are expensive. I replaced one on my Jeep and about had a heart attack. Anyhow, I'm hoping to build the engine exactly like you're planning. We should collaborate on this effort man. I've got a friend that gets Honda parts very cheap, hopefully he can get the Acura parts also. My question is are you planning on buying a new transmission? I'd hate to spend all this money only to have a shitty transmission. I suppose just take it easy on it right? Goodluck and I'm sure I'll be seeing you around.
Noel
Old Jul 3, 2002 | 10:03 PM
Ltech's Avatar
Default Re: Resleeve Project (noel)
GE sleeves bore & hone, JE pistons 9:1 $1350
Eagle rods $315
ACL bearings $90
Balance and blue print $50(I got the hook up)
It's not including gaskets and other bs.
lickety_britches
May 28, 2008 09:24 PM
TcUiRvBiOc
May 16, 2007 01:29 PM
grappler
Apr 13, 2007 10:28 AM
bstdlsteg69
Sep 15, 2006 12:30 PM
DjFreeze
Nov 22, 2002 08:19 AM
