for a drag kit....
Old Jul 3, 2002 | 09:31 AM
ceemarun's Avatar
Default for a drag kit....
on an gsr, is there any sorta of cutting or shaving you have to do? im sure you gotta cut the fan for the turbine to fit, but do you have to shave the block or anything?
Old Jul 3, 2002 | 09:36 AM
Adi Radoncic's Avatar
On Fire!
Default Re: for a drag kit.... (ceemarun)
you have to shave the block a little...
Adi
Old Jul 3, 2002 | 09:37 AM
Trigun's Avatar
depends on the turbo size ... i'm pretty sure most had to shave a little off the block and/or fans.
with my maxrev mani and garrett turbo, i had to cut ALOT from both.
Old Jul 3, 2002 | 09:40 AM
ceemarun's Avatar
Default Re: for a drag kit.... (Trigun)
i just did a search, and if its the b-trim, you gotta shave, but if its the e, you dont. so just a bit of drumel work?
anyone has a pic of this, that'd be great.
Old Jul 3, 2002 | 09:44 AM
Trigun's Avatar
dremel and cutting disks should work but we used a drill and drilled a bunch of holes close together and got a mallet and pounded out the loose piece.
Old Jul 3, 2002 | 09:45 AM
BlwnBlue's Avatar
I think you might have that backwards...the e is bigger..therefore requires a little shaving..I have a b on my si and didn't have to shave the block..
Old Jul 3, 2002 | 09:46 AM
lucas569's Avatar
http://imglib.************/index.cgi
everything you need is right there.
Old Jul 3, 2002 | 09:54 AM
ceemarun's Avatar
Default Re: for a drag kit.... (lucas569)
that was just a whole lot of pics! no pics on shaving the block tho
Old Jul 3, 2002 | 11:08 AM
Etylorcen's Avatar
Are you not sure where you need to shave? Or just how much? If you look where your turbo would be once you install it onto the manifold you can see to the left that there is a small webbing on the block. Just gotta grind that down a little so it doesnt touch the turbo.
sfwdcrx
Mar 19, 2008 02:33 AM
gsrboost
May 5, 2005 09:14 AM
FredoSP
May 12, 2002 08:05 PM
intekragsr
Jan 27, 2002 06:38 PM
AllMotorITR
Nov 30, 2001 09:20 AM
