just talked to rc
Old Jul 3, 2002 | 11:33 AM
thejdmkid's Avatar
Default just talked to rc
i'm getting my fuel stuff all ready for my build next week. i spoke to rc today. i'm gonna get 550cc injectors they said they only come in <U>low resistance </U> what does this mean .
Old Jul 3, 2002 | 12:17 PM
93LSivic's Avatar
Default Re: just talked to rc (thejdmkid)
Means they are peak and hold type injectors. You will need a resistor box from an older OBD0 car to run them if you are OBD1. IF your OBD2 you'll still need the resistor box and also OBD1 injector clips.
Old Jul 3, 2002 | 06:13 PM
BlueShadow's Avatar
here is a link that explains the relationship between high or low impedance injectors and high or low impedance drivers (ECU/standalone)
its from an RX7 board though, and to clear up some confusion I'll translate some of the acronyms.
PFC = Apexi PowerFC (standalone management system)
high impedance injectors = saturated injectors (and vice versa, just another way of ID'ing the injector)
low impedance injectors = peak-and-hold injectors (and vice versa)
FD = RX7
http://www.rx7club.com/forum/showthr...threadid=79310
Old Jul 4, 2002 | 04:45 AM
turbo Si's Avatar
I have a set of RC 550 injectors used for sale. Although I will let them go in a few weeks. I need them to break in my motor sisnce these are the injectors my AEM is tuned for.
Old Jul 4, 2002 | 02:54 PM
thejdmkid's Avatar
Default Re: just talked to rc (turbo Si)
ok so i have a 96 rs integra that this is going into it is going to use a 94 ls ecu an the greddy piggy back, with all coresponding hardware ie; injector harness, ignition harness, boost cut limiter, an i also have the greddy software to adjust fuel an so forth. so is this good enough to run those injectors?
accordin 2 me
Dec 16, 2011 06:00 AM
dave24
Aug 3, 2006 07:43 PM
aaronhume
Oct 25, 2005 11:52 PM
1strdko
Dec 16, 2003 06:38 PM
