Turbo hitting oil stick
I just took out my exhaust manifold with the turbo yesterday to fix something
then i found out that my turbo is in contact with the oil stick, that metal pipe
i can still push it in, it's not in the way that much, but it still touches the turbo
will this cause any problems??
is this possible to make a sound when the turbo is ON??
coz i am hearing a sound like "tak tak tak" would it caused by this when it vibrates when the engine is oN??
Re: Turbo hitting oil stick (SlowB16)
i tried, but it's damn hard
and then i thought maybe that stick won't be able to go in
well, maybe i will need to take off my exhaust manifold again !! ?? haha
Re: Turbo hitting oil stick (xbird)
mine rubs up against my delta wastegate and exhaust manifold, the rubber scorched off the tip of the top of the dipstick LONG AGO....but i just deal with it and only check my oil when the car is cool (if not i would have 10th degree burns all over my arms and fingers)
Re: Turbo hitting oil stick (JMinSi2000)
i have thought this before
but the point is, DO I NEED TO?
would it cause any problem if i keep it like this??
thanks
thanks
