compression ratios
Old Jul 7, 2002 | 12:17 AM
deviant1's Avatar
Default compression ratios
would the stock compression ration be safe on a turbo LS motor? i ask because i want to build up a motor first (sleeved,pistons (stock CR),rods,etc...) and then drop it in without the turbo so i can drive the car. i know with lower CR pistons the car will lag and i would have to save up for a turbo. but i need a car so would the stock LS (B18B) compression be ok in a turbo car thats built?
Old Jul 7, 2002 | 12:34 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: compression ratios (deviant1)
No way, put the turbo on now and enjoy it. In the mean time you can plan your rebuild. Its cheaper in the long run and you clan learn and plan ahead to have a killer built motor.
88hbz6
Nov 25, 2008 07:48 PM
jfteg
Jul 29, 2005 05:35 PM
scUba-stEve
Apr 2, 2005 06:23 PM
Flexin5
Aug 31, 2004 02:58 AM
MisterB
Nov 20, 2001 11:09 AM
