stock or upgraded fuel pump?
Old Jul 5, 2002 | 08:20 PM
boostedcivic's Avatar
Default stock or upgraded fuel pump?
With a custom turbo kit on a GSR that is similar to a Drag 3 kit, is it best to use the inline pump with the stock pump or with an upgraded pump? TIA
Old Jul 5, 2002 | 09:02 PM
Dutchie's Avatar
Default Re: stock or upgraded fuel pump? (boostedcivic)
You will be fine with the stock pump.
Old Jul 5, 2002 | 11:20 PM
rjardy's Avatar
Default Re: stock or upgraded fuel pump? (Dutchie)
Maybe not, what kinda boost are you runing, allso what turbo?
Rob
Old Jul 6, 2002 | 12:19 AM
Dutchie's Avatar
Default Re: stock or upgraded fuel pump? (rjardy)
Well I'm assuming he's using a 12:1 with stock injectors and probably 7 psi max. The stocker with inline will be fine for that.
Old Jul 6, 2002 | 12:42 PM
Dutchie, you are correct in your assumption of 7 psi and the stock injectors. Thanks for the replies.
TrueUntilDeath.com
Jan 25, 2005 04:45 AM
EE_Chris
Jul 31, 2002 09:17 AM
dwilson
Apr 10, 2002 08:41 PM
