3mm headgasket
Old Jul 3, 2002 | 07:12 AM
teamrocket si's Avatar
Default 3mm headgasket
Are these headgaskets(blitz, inline pro) reliable enough to turn up the boost on an internally stock b16(with engine management) to around 12lbs of boost? or is it just b.s.?
Old Jul 3, 2002 | 07:20 AM
b18bturbo's Avatar
Default Re: 3mm headgasket (teamrocket si)
you can probably run around 20psi with a 3mm head gasket safely with standalone mangement.
Old Jul 3, 2002 | 07:21 AM
CovertFI's Avatar
Default Re: 3mm headgasket (b18bturbo)
how much do thies head gaskets run?
Old Jul 3, 2002 | 07:26 AM
b18bturbo's Avatar
Default Re: 3mm headgasket (CovertFI)
the cometic ones are the chepest at 115 dollars then blitz,greddy,hks all have theres which are 200 or so and then inline pro has them as well for little higher like around 285 or so..
Old Jul 3, 2002 | 08:33 AM
CovertFI's Avatar
who sells the cometic?
Old Jul 3, 2002 | 09:11 AM
DSF's Avatar
DSF
http://www.raceeng.com/showItems.asp...Supplier=19579
.112" = 2.8mm
Old Jul 3, 2002 | 04:57 PM
DRAGLS's Avatar
Default Re: 3mm headgasket (DSF)
I have a cometic 3mm headgasket for vtec motors(dohc) $100 obo sent to your house. never been used I went LS
Old Jul 3, 2002 | 05:13 PM
rice4life's Avatar
Default Re: 3mm headgasket (DRAGLS)
how much compression does the 3mm gasket drop on b16a
Old Jul 3, 2002 | 05:16 PM
DRAGLS's Avatar
Default Re: 3mm headgasket (rice4life)
between 8.5 or 9 to1
Old Jul 3, 2002 | 05:31 PM
CovertFI's Avatar
i have a sohc
Old Jul 3, 2002 | 07:32 PM
Max_ED9's Avatar
Cometic make one for the dohc ZC?
Old Jul 3, 2002 | 11:05 PM
JDM EX's Avatar
Default Re: 3mm headgasket (maxracing)
Go for Inline Pro.. I think this product is good for boost.. Anyway try it..
Old Jul 6, 2002 | 12:52 AM
Pwerdr's Avatar
Call Dynamic Autosports about the 3mm headgaskets, they sell them for much cheaper than anyone else. I think it is the same one that all the guys are buying. Don't buy the japanese ones, they are a rip off.
949-457-1234
dominate9
Jan 15, 2006 04:27 PM
D-meet07
Nov 4, 2004 06:29 PM
civictyper85
Apr 11, 2003 06:57 PM
InfamousRS
Dec 15, 2001 06:02 PM
Charles B.
Oct 29, 2001 09:26 AM
