Supercharger almost done!
Old Jul 2, 2002 | 04:39 PM
TedR719's Avatar
Default Supercharger almost done!
Well yesterday on my birthday I started on the JRSC install. Well everything went pretty smooth untill the last part of the night. We had one of the bolts on the tensioner break so I will have to get it machined out and rethreaded. Also we have a few wires on the ECU that need to be hooked up.
The car started the first try but was idleing pretty high and the belts were not lined up as they should be. So I just need to get those 2 things fixed and hopefully this thing will be up and running on Monday
Old Jul 2, 2002 | 04:40 PM
TedR719's Avatar
Default Re: Supercharger almost done! (futuresi)
I have a problem with my belts being "stright". The problem ones are the ones that connect to the alternator. alternator/crank and the superchager/alternator.
When my pulley was put on they had to put a spacer for it to work.
We got both idler pulleys on and the belts tensioned. Now when it started it was ideling around 1500 and sounds like a vac leak.
We took a look and the top clamp for the bypass was not on so we tigthen one in there and now it doesnt sound as bad but not ideling as it should. I also was thinking it could be from the boost gague line that was open since I havent connected it to the gague yet (line was too small)
Now the belts, they are not lining up at all. They are both the ones from the alternator. The s/c belt it rubbing against the alternator and look like its only on 2 grooves. The other alternator one is about 1-2 grooves off. Is there a spacer for the alternator when you out it on the bracket? cause it need to move over somehow....
any idea guys?
Old Jul 2, 2002 | 06:24 PM
TedR719's Avatar
ttt, anyone with some knowledge about this?
Old Jul 2, 2002 | 07:31 PM
Holden's Avatar
On the lower alternator support bolt, there's a collar that centers the bolt as it passes through the bracket. It usually sticks inside the stock alt. bracket and can easily be forgotten.
Did you pop the collar out of the stock bracket and use it with the JR bracket?
Old Jul 2, 2002 | 08:14 PM
TedR719's Avatar
Default Re: Supercharger almost done! (Holden)
Humm I dont remeber no collar. I will check my parts box to see if I have an extra part. Will that throw it off that bad though? I will start on this tomorrow morning and see what come from it.
What does it kinda look like?
Thanks
sickiziu
Aug 14, 2008 09:58 AM
mjrino
Feb 18, 2007 08:31 AM
thehatchninja
Aug 29, 2006 07:01 PM
typerhedlights
Jun 3, 2005 12:56 AM
folicor
Jul 29, 2003 09:42 PM
