boost problem maybe fuel problem
Old Jul 6, 2002 | 07:52 PM
mikelcrx's Avatar
Default boost problem maybe fuel problem
I have 310cc injectors, msd inline fuel pump, fuel pressure regulator , and a 12:1 fmu. My question is are all of these componants the right thing for my turbo appplication? Before I put the fmu on the car I could stomp it in third gear and it would fly, but when I start out in first and second the car would hesitate and bog down, I just can't figure it out. It's pretty fustrating and pretty damn scary to know that I might blow up my car tuning it and that was before i added the fmu. Since I added the fmu the car doesn't want to run at all. Please help!!!!! I'm running 7pounds of boost with intercooler and 1g bov.
Old Jul 6, 2002 | 08:13 PM
inspyral's Avatar
Default Re: boost problem maybe fuel problem (mikelcrx)
310's and a 12:1 seems a bit rich to me...
Old Jul 6, 2002 | 08:51 PM
falcongsr's Avatar
What is this crap?
you're probly way rich with 310s and 12:1. whats your fuel pressure set at?
Old Jul 6, 2002 | 09:02 PM
B20C5 Turbo's Avatar
New User
I assume that you have the Vortech FMU. If so, get yourself a 5:1 disk set. They work great with the 310's.
Old Jul 6, 2002 | 09:11 PM
mikelcrx's Avatar
Default Re: boost problem maybe fuel problem (B20C5 Turbo)
thanks for the info and you have a good saying.
Old Jul 6, 2002 | 09:20 PM
mikelcrx's Avatar
do you think even without the fmu i'm still running rich and maybe i need to put the factory 240cc injectors back in with the 12;1 fmu?
Old Jul 6, 2002 | 10:20 PM
Dutchie's Avatar
You will be running rich at idle and low throttle conditions, but lean at full throttle. I would say get an 8:1 disk and an AFC to trim fuel at idle. Right now you would probably be better off with the stock injectors until you can get a different disk for the FMU.
slowpokesi
Nov 6, 2004 04:14 PM
havok hybrid
Sep 23, 2002 05:01 PM
mikelcrx
Jul 9, 2002 09:14 PM
uneekcrx
Apr 26, 2002 08:16 AM
FBP Ex-T
Feb 16, 2002 04:39 PM
