hondata 2b question
Old Jul 5, 2002 | 03:09 PM
TurBoTeG's Avatar
Default hondata 2b question
Now when you buy this..it is preprogrammed for stock injectors and everything??? Sorta new with this...but i have been reading achived topics along with the hondata website for 3 hours...and im still confused on some things...
Old Jul 5, 2002 | 03:20 PM
W.Zero's Avatar
Default Re: hondata 2b question (TurBoTeG)
when you buy the hondata the place you buying it from should tune the same day as installing the unit
Old Jul 5, 2002 | 03:45 PM
Quaalude's Avatar
the place u buy it from programs a base map onto the chip....the base map will be setup for your particular engine, injectors, and turbo....i.e. if u have a b16 turbo with 550's, then the shop will include a base map for a b16 turbo with 550's....it is just a base map to get u running but u will need to fine tune it on the dyno or street tune with wideband O2
Old Jul 5, 2002 | 05:11 PM
DragII's Avatar
25 Year Member
Default Re: hondata 2b question (Quaalude)
yup they should give you a limp a long basemap for your personal set up.
Old Jul 6, 2002 | 12:27 PM
TurBoTeG's Avatar
Default Re: hondata 2b question (DragIIDigital)
well if i change anything after they pre program it....say to bigger injectors...do i have to go back to the dealer and have it reprogramed???
Old Jul 6, 2002 | 12:30 PM
prophet's Avatar
yes.
1baddcivicsi
Engine Management and Tuning
Apr 10, 2016 10:21 AM
Colorado_teggy
Dec 20, 2014 03:11 AM
88crxhfb16
Aug 3, 2005 01:57 PM
ITR9788
Jun 9, 2004 02:14 PM
JeremyL
Feb 20, 2003 10:12 AM
