FP with DSM 450s?
Old Jul 3, 2002 | 08:45 PM
inspyral's Avatar
Default FP with DSM 450s?
Sorry if this has been covered, but a search yielded nothing. What fuel pressures are you guys running with your DSM's? Mine are going in this weekend, hopefully.
Old Jul 3, 2002 | 09:19 PM
zojirushi's Avatar
Default Re: FP with DSM 450s? (inspyral)
fuel pressure should remain the same.
Old Jul 3, 2002 | 09:48 PM
inspyral's Avatar
Default Re: FP with DSM 450s? (zojirushi)
So if I'm running 40/50psi vac/atmospheric right now, I should leave it there?
Old Jul 3, 2002 | 11:22 PM
zojirushi's Avatar
wait a min... are u running a s-afc??
if u are, u can leave the fuel pressures the same and use the afc to tune the fuel down.... otherwize, u'd have to mess with the fuel pressures big time. Its not a good idea to run 450's on a motor without at least using a s-afc. Playing with the fuel pressure is not the right way.
Old Jul 3, 2002 | 11:44 PM
inspyral's Avatar
Yes, I'm running an AFC, and it's going to be setup a la the "hack", -40% fuel trim across the board. I was asking what fuel pressures people who are running the AFC hack are using. Sorry for not making that clear.
Old Jul 4, 2002 | 03:42 AM
boostinb18's Avatar
im pretty sure you run stock fuel pressure with the vafc safc hack! at least thats what the breator of it runs...and it runs great!
Old Jul 5, 2002 | 02:59 PM
zojirushi's Avatar
Default Re: FP with DSM 450s? (boostinb18)
use stock fuel pressures
Old Jul 6, 2002 | 10:26 AM
inspyral's Avatar
stock is like 38/45, right? I just did the install last night, and it seems to run pretty well, with a little hesitation if i let off the throttle for more than a couple seconds.
Old Jul 6, 2002 | 11:12 AM
SiRkid's Avatar
kinda ot...but is my 6 ohm resistor pack(from an old acura legend) gonna work or should i get another one?
Old Jul 6, 2002 | 11:16 AM
inspyral's Avatar
Default Re: FP with DSM 450s? (SiRkid)
got this from Hondata:
High horsepower boosted cars often need large injectors. Most large capacity injectors are available in peak and hold form - about 2 ohms impedence, whereas most stock injectors from about 92 on are saturated (8-10 ohms impedance). Honda engine computers require a total injector impedence of about 10 ohms so a resistor pack is needed whenever the stock saturated injectors are swapped with peak and hold.
Old Jul 6, 2002 | 02:39 PM
turbozc2001's Avatar
my set up idle 24psi on b&m regulator with hack safc running on dsm 450cc injectors. Runs perfect all the rpm and even in full boost 9psi.....
Old Jul 6, 2002 | 02:49 PM
inspyral's Avatar
Default Re: FP with DSM 450s? (turbozc2001)
24 with or without vacuum?
Old Jul 7, 2002 | 03:10 AM
24psi with vacuum....
Old Jul 7, 2002 | 03:11 AM
inspyral's Avatar
sweet, thx
Old Jul 7, 2002 | 03:18 AM
sure... nice car
s032105k
11
Apr 14, 2011 08:01 PM
Tchleung
Feb 27, 2005 07:52 PM
88redrex
Dec 12, 2004 01:04 AM
wontonracer
Mar 16, 2003 06:05 PM
kyle h.
Mar 11, 2003 03:58 AM
