some guy had to put regular in...
Old Nov 24, 2010 | 10:28 PM
terbear4god's Avatar
Default some guy had to put regular in...*Updated* not fixed
so im pretty sure one of my local gas stations put regular in my boosted ls-vtec i hate having someone else pump gas
so i believe i was at about a quarter tank so the guy put about another quarter of regular in with the premium the car is fully tuned for premium.
as of right now i went out and topped it off with premium about halftank giving me a full tank
im getting really rich air/fuels about 11 to the bottom of the aem air/fuel gauge(10) in green just holding a steady cruise..
how should i go by getting rid of the regular i just put the premium too top it off about 5 miles ago will it eventually burn it up? should i drive it pretty much till its dry?? just do not wanna burn up my brand new motor with less than 5k on it.. any replies help! thanks!
Last edited by terbear4god; Nov 26, 2010 at 11:18 PM. Reason: new information problem still occurring
Old Nov 24, 2010 | 10:50 PM
Default Re: some guy had to put regular in...
should i just keep it driving on the freeway till the gas light comes on? just don't boost and ill be okay right?
Old Nov 24, 2010 | 11:05 PM
golf-mk3's Avatar
yeh dont boost drive around normally eventually it will all burn then fill up with 93 and u should be golden. i pumped 87oct by accident couple years ago and thats what i did.
Old Nov 24, 2010 | 11:10 PM
thanks a bunch man!
the reassurance makes me feel good about driving it lol
its my first boosted civic and boost+vtec sounds like ***** gonna explode lol i just cruise it anyway..boost scares the sh*t out of me haha
Old Nov 24, 2010 | 11:35 PM
AllShowNoGo727's Avatar
^ fear is good, makes you know your making power
Old Nov 25, 2010 | 11:33 AM
94civiccupew/b7's Avatar
^ hell yeah it is lol. another idea is to throw a gal. of toluene in to raise yur octane up. has a 114 rating and has no adverse affects
Old Nov 25, 2010 | 01:57 PM
blackeg's Avatar
its not really good for your fuel pump to run it empty. they use the gas they are submerged in to help with heat dissipation. you might be better off draining the gas you have in out and use it for the lawnmower or regular car...
Old Nov 25, 2010 | 06:20 PM
http://www.team-integra.net/sections...ArticleID=1260
good article on octane rating. where i got the info about using toluene
Old Nov 26, 2010 | 04:51 PM
jDMJeRk's Avatar
Couple things come into play here- how much boost are you running? Whats the compression ratio? Do you beat the **** out of your engine? How well was the car tuned? Does it have the knock sensor still?
Given the average case scenario your probably just fine. I wouldn't worry about it too much. I wouldn't add any additives to increase the octane (other than fuel, maybe some unleaded 109 depending on availability, if your that worried about it) as that will just foul the plugs out.
But more importantly, how safe is your tune to even begin with if your crusing around with air fuel readings of 11:1 > richer?! If your not in boost there is no reason to be cruising at an a/f ratio like that ever.
Old Nov 26, 2010 | 11:05 PM
i just got it a couple weeks ago..
ran the regular out and now just got all premium and its still occasionally doing it mostly now its reading and holding about a 13.0 cruising but at idle sometimes still drops down too 10.5-10.0 if not it ready correctly at 14.6-15.0
its a fully tuned p28 on chrome pro normally it always ran 14.6-15.0 at cruising and at an idle it just randomly started up a couple days ago..im also thinking that their never was regular in it...
i was told that it might be that the plugs fouled up..would that cause the air/fuel readings too act up?
Old Nov 27, 2010 | 05:58 AM
i could be. with fouled plugs your air fuel mixture might not be getting a full burn in the cylinder sending raw fuel out the exhaust showimg a rich mix on your o2. wouldn't hurt to try it. how long has it been since you've changed them? In my experience ive been able to get about a good 3k-4k on them before needing changed and that's pushin it.
Old Nov 27, 2010 | 07:30 AM
when i picked it up their was 3200 miles on the fresh motor iv been driving a lot its my daily 90miles a day but i don't ever boost during that maybe once a day so iv put about 1500 miles on it so yea you might be right thought they lasted a lot longer than that but i don't know my boosted civic yet
thanks for the comments!
Old Nov 27, 2010 | 10:39 AM
ngk bkr7e's at .030 gap is wat u want
Old Nov 28, 2010 | 04:02 PM
drvfast's Avatar
Default Re: some guy had to put regular in...*Updated* not fixed
thanks!
If it was me I would drain the tank and fill up with the correct octane. I know gas is expensive, but its better the ruining a motor.
Old Nov 29, 2010 | 10:31 AM
iv ruled out the possibility that someone put regular in after a couple tanks of premium and its still doing it
what would cause my ride too suddenly be fine one moment than rich the next without me changing anything fully tuned??
i put new plugs cleaned a bunch of sensors could the o2 sensor that the ecu runs off be causing it?
widewhite
Dec 27, 2014 01:29 PM
Buktheng
Honda Fit
11
Jan 2, 2008 04:12 PM
gosu08
Nov 6, 2006 02:44 PM
vw_ev71
Nov 6, 2002 10:41 PM
Jesse H
Dec 19, 2001 02:07 PM
