MBC hooked up correctly?
Old Nov 20, 2010 | 06:18 AM
Broken Gearbox's Avatar
Default MBC hooked up correctly?
Right?
Or do i need to switch the 2 vacuum hoses' at the MBC the other way around?
Old Nov 20, 2010 | 09:18 AM
DelSolMarine's Avatar
Default Re: MBC hooked up correctly?
its hooked up properly... but that one hose it looks like its really being tugged against by your upper radiator hose.. i would run that underneath the radiator hose or extend it by about an inch... you dont want those hoses coming off... and put mini zip ties around the attachments to assure they are secure...
Old Nov 20, 2010 | 09:01 PM
boosted91crx's Avatar
i am not familiar with that version however if it works like most it is hooked up backwards. but like i said i am not sure on that version what they did inside it it could be different then the rest.
Old Nov 21, 2010 | 09:14 AM
Well its a Hallman boost controller...the little ball is on the line that goes to the WG
rat387
Feb 10, 2011 06:34 PM
steveharrmr23
Aug 19, 2008 03:25 PM
oddmut
Apr 25, 2008 10:38 AM
billy hoang
Jan 21, 2007 01:17 PM
huntarrr
Dec 14, 2006 03:51 PM
