How big is too Big for a 38mm
Old Dec 19, 2010 | 10:34 AM
ChingaDEboost's Avatar
Default How big is too Big for a 38mm
hey just wondering what turbos yall guys are running .. i have a turbo LS and just got my manifold cermic coated not thinking i was wanted to go bigger than my ebay t3 50 trim now i want more power which means bigger turbo ... what the max turbo you guy think i can have with out boost creeping or havin' any issues what so ever with my 38mm wastegate ...
here are some random pics of the setup ..
Old Dec 19, 2010 | 10:42 AM
boosted94gsr's Avatar
Default Re: How big is too Big for a 38mm
I was running a 35r on my stock gsr at 12psi with a 38mm gate and no boost creep. Then I built and sleeved the block to 84mm with the same manifold and waste gate and it wouldn't hold less the 17psi so I had to upgrade to a 44mm waste gate. Tuner said it was because the motor became more efficient and could flow more air with the bigger bore so the 38mm gate couldn't keep up any more.
I also depends on what manifold you run and what kind of waste gate placement it has.
Old Dec 19, 2010 | 10:47 AM
Garage 808 Hatch's Avatar
I had a HY35 on a sohc with a single MVS 38, worked great
Old Dec 19, 2010 | 10:49 AM
i was think of running a 35r on mine or the famous 60-1 but nothing bigger
BTW i going stock block for now...
the waste gate is a JGS precision on a 9lbs spring .. so far so good on 14 psi but i think i wanna go up to about 18 to 20 lbs on the next setup
Old Dec 19, 2010 | 10:55 AM
siblues's Avatar
I am running a tial 38 with a sc61 at 18 pounds of boost with no issues.
Old Dec 19, 2010 | 10:58 AM
what setup ..
Old Dec 19, 2010 | 10:59 AM
that is another thing i should of done is swtich over to a ****ing v-band
Old Dec 19, 2010 | 11:07 AM
what do yall think about this turbo
I know its a cheap turbo but i been using there 50 trim at 14psi with no problem making over 300+hp on it with no smoke or no shaft play
http://www.speedyracer.com/servlet/t...charger/Detail
Old Dec 19, 2010 | 11:23 AM
ls_on_boost's Avatar
my ls non vtec made 419whp at 22psi 57 trim turbo 38mm tial wastegate top mount
Old Dec 19, 2010 | 12:27 PM
sanman000719's Avatar
i have ran my pt67 on the 38mm gate with 26psi made 650ish
Old Dec 19, 2010 | 02:08 PM
what brand
Old Dec 19, 2010 | 03:05 PM
Originally Posted by ChingaDEboost
what brand
manifold?cc fab turbo is a garrett
Old Dec 19, 2010 | 10:06 PM
siblues's Avatar
B16 in an em1 with a ramhorn and 3 inch downpipe.Simple setup and I am running an s cover on the sc61
Old Dec 19, 2010 | 10:23 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
just wondering how was spool on a 1.6l with the hy35? when did it start as well as how fast did it build.
sorry for the thread jack but the w.g. really depends on how low you wanna run with said turbo. if you run higher boost you really don't have to worry much about boost creep. its when you have a big turbo and wana run low boost is when it just wont cut it. btw your ls-t is beautiful.
Old Dec 20, 2010 | 08:08 PM
the effectiveness of the WG will be shown in the lower boost settings, not higher. ability to hold lower boost, and not creep.
Trevor, spooled up pretty slow, a little better than my s372 on my crx lol
Old Dec 20, 2010 | 08:20 PM
Loved
Community Favorite
O, well that throws that idea out the window lol.
Old Dec 21, 2010 | 06:50 AM
90blackcrx's Avatar
Thanks for saving me some typing....
Old Dec 21, 2010 | 06:56 AM
sleepencivic's Avatar
trying to run low boost is where you will have an issue with the 38mm
karmadhi
Oct 1, 2011 04:12 PM
2fastek
Dec 7, 2008 07:31 PM
boostdummy
Oct 28, 2005 08:37 PM
mrx
May 12, 2004 11:20 AM
NateTEG95
Sep 12, 2003 10:04 AM
