high compression turbo ?
Old Nov 29, 2010 | 09:33 PM
93delslow315's Avatar
Default high compression turbo ?
can i still boost my all motor b16 as long as i only ran 5 pounds of boost?
my mods are
i/h/e
s2 intake manifold
blox 68mm throttle body
blox type c camshafts
dh racing valvetrain
eagle rods
je pistons 81.5mm bore 11:5:1 compression
thanks guy let me know what you think, if not definately changeing the pistons out
Old Nov 30, 2010 | 12:19 AM
civicfd2's Avatar
Default Re: high compression turbo ?
yes you can on that C/R but you must run a high octane fuel like C12 or E85. and you will also need a good tuner to tune your car so you dont run into detenation.Try to get air from the turbo moveing into the engine faster and exiting the engine even faster.
Old Nov 30, 2010 | 12:22 AM
Tony the Tiger's Avatar
Your biggest concern is to find a tuner that is experienced with high compression turbo setups. Ask him what kind of setup you should run (turbo sizing, exhaust sizing, fuel requirements, etc...)
I have tuned a lot of high compression turbo setups before, and it is totally doable with pump gas depending on the setup you choose.
Old Nov 30, 2010 | 12:24 AM
hillssol95's Avatar
this would be amazing turbocharged but you would have to use higher octane....i think you should do it with e85 (104 octane if i remember right) and 1000cc injectors. agreed you definitely will need a good tuner!
Old Nov 30, 2010 | 12:26 AM
hillssol95's Avatar
11.5 turbocharged on pump? that sounds risky to me, but im not a tuner.
Old Nov 30, 2010 | 12:31 AM
I've done that back in '03-06.. I had a GT28RS setup at 11.5:1 CR on Sunoco 94oct pump... 320 WHP at 14 PSI for about a year (10k miles). And then I had a GT2871R on there, and had 380 WHP for about 2 more years (20k miles). I am the tuner, so that's a different story.
Old Nov 30, 2010 | 12:33 AM
hillssol95's Avatar
i wasn't doubting I've read some of your other posts and i believe you. I'm just saying i'd feel safer running higher octane.
Old Nov 30, 2010 | 03:33 PM
GEN2 LS's Avatar
Loved
you should be fine with that compression ratio if you have access to E85. check out my stock block b16 with CTR pistons boosted on E85. made good power!
https://honda-tech.com/forums/forced-induction-16/turbo-da-b16-hi-compression-e85-8-9psi-dyno-graph-2867158/
henchie
Mar 28, 2016 07:20 AM
CXtypeR
Feb 28, 2007 10:44 PM
Dasani
Jul 7, 2006 05:13 AM
LSEGHATCH
Oct 6, 2004 07:44 PM
transmission11
Dec 30, 2002 10:02 PM
