h22a stock internals turbo questions... please help!
hi, I am new in honda-tech, hope you guys can help me. I have a h22a stock internals (stock pistons,rods,cams) and want to know: how much pound of boost can it handle, and like how many hp should I get from it. I have, 1000cc injectors, tial blow off, turbo smart 38mm wastegate,gt35bb .82 turbo.
Re: h22a stock internals turbo questions... please help!
If you have an efficient setup (NOT a log manifold) with low backpressure, there is no reason you cant run mid 300whp reliably.
Also, he didn't state it was a daily or not. I would not run anything over 300whp on a stock h22 if it is a daily. If it is a garage *****, that is a different story.
1 Post
It's not odd. I said they are prone to failing after 300 whp. I didn't say they will. Everyones setup, tune, engine is different. Some will hold 380whp fine, and some will only hold 315whp and pop 8 months down the road.
I wouldn't say the ring lands are prone to failing, I'd more so say that after 300hp the setup isn't as reliable as a stock motor, but if its tuned right and the turbo setup is pieces together well, 300hp and above is safe.
BUT being that you are a 'trial user' and this was your first post OP, I doubt you will see any of this........so now im just talking to myself. Wierd....
So, I know what a gt35 tubo is, but not too sure what the .82 is for? Is that for the a/r? Is that referring to the hot side or the intake side?
