vacuum block question
Old Dec 2, 2010 | 09:18 AM
kwah's Avatar
Default vacuum block question
hi, i got a blox vacuum block. I did the following hose connection.
i connected the hose that comes from the brake booster to the one side of the block and from the other side i pulled another hose and connected it on my IM.
thats correct or i did it wrong?
Old Dec 2, 2010 | 11:33 AM
ryguy2588's Avatar
Default Re: vacuum block question
You can run a vacuum line from the IM through the vacuum manifold and into the brake booster, or I just see a lot of people "T-ing" off the brake booster, running it to the vacuum manifold, and capping off the other side of the manifold. What ever works for you.
Old Dec 2, 2010 | 04:33 PM
Silva Bullit DC4's Avatar
Yes, cap off the other side of the block, you'll be fine seeing vacuum from the brake booster line only. That's how I had my T1 block set up, no issues.
Old Dec 4, 2010 | 10:36 AM
kwah's Avatar
i have a Golden eagle intake manifold. there are 2 exits from the manifold. the first one the brake booster hose goes there. and the other one is closed. If i open that and connect a hose going from there to the vacuum block this will be ok? It creates vacuum or its has to be from the brake booster?
Old Dec 4, 2010 | 12:08 PM
Yes, that's fine.
nu2teg
Apr 10, 2026 03:05 PM
CRXREFIC
Dec 17, 2010 09:16 PM
Fuster_Cluck
Mar 9, 2008 04:41 AM
TehMan
Mar 20, 2006 12:49 PM
FredoSP
Apr 12, 2004 09:21 AM
