Blue Smoke When In Boost
Old Dec 13, 2010 | 04:48 PM
egboy94's Avatar
Default Blue Smoke When In Boost
Hey guys i just recently bought a turbo from miketurbo inc. my car smokes going into boost and on deceleration.. i just changed the valve seals thinking that maybe that was the problem but it still smokes... i did a compression test & the results were:
#1{200}
#2{200}
#3{200}
#4{200}
i have a top mount manifold i don't know actually where you guys weld your -10 bung on the oil pan but mine is in the center as high as it can go.. {idk maybe the bung location isn't allowing the oil to drain back fast enough}
if anyone can share some advice i'd really appreciate it!!!
Old Dec 13, 2010 | 05:36 PM
up&atam's Avatar
Default Re: Blue Smoke When In Boost
Your return line seems like its in a good spot. What turbo are you running? Did you run a restrictor on the oil feed line to the turbo? Is the turbo new, if not it could be the seals.
Old Dec 14, 2010 | 02:00 PM
egboy94's Avatar
6265... i tried a restrictor that didnt change anything... turbo is brand new..
Old Dec 14, 2010 | 03:13 PM
QwkD16's Avatar
Heres a tip: Blue smoke is oil that is mixed with fuel then fired, thats what makes it turn blue. White smoke, on a turbo car, is USUALLY the turbo seals pushing small drops of oil right into a hot downpipe. White smoke can also be water burnt. Grey and black smoke is too much fuel.
Old Dec 14, 2010 | 03:16 PM
egboy94's Avatar
smoke is blue!
Old Dec 14, 2010 | 03:54 PM
spectacle's Avatar
Sounds like you have a problem in the motor. Do a leakdown
Old Dec 14, 2010 | 04:59 PM
Ls_dx's Avatar
valve guide seals
Old Dec 14, 2010 | 06:00 PM
Axix24's Avatar
i am going to go with the turbo being the issue...
Old Dec 15, 2010 | 12:52 PM
egboy94's Avatar
Originally Posted by Ls_dx
valve guide seals
brand new
Old Dec 15, 2010 | 02:59 PM
QwkD16's Avatar
I have blown turbo seals and the smoke is white. So did my friends turbo Integra. I rebuilt his turbo and the smoke went away. Mine is next. Blue smoke is usually engine problems.
Old Dec 15, 2010 | 04:23 PM
egboy94's Avatar
i spoke to the guys that built my turbo they said they will inspect it and rebuilt it free of charge if anything is wrong with it
Spoon84
Sep 27, 2010 05:35 PM
GEN2 LS
Jun 3, 2008 07:16 PM
SpOoNisMyFriEnD
Nov 9, 2005 06:11 PM
crispydee
Oct 1, 2004 09:23 AM
highmilehatch
Nov 7, 2003 06:35 AM
