b20 vtec turbo dyno graph & boost chart
Old Dec 17, 2010 | 03:05 PM
ShanghaiOC's Avatar
Default b20 vtec turbo dyno graph & boost chart
Scan_Doc0003.pdf is the Dyno Chart. I had ignition breakup on the 9psi run.
Scan_Doc0004.pdf is the Boost Graph. It held pretty steady.
The correct numbers at 6.89psi is the blue run, and the 8.56psi run is the orange.
File Type: pdf
File Type: pdf
Old Dec 17, 2010 | 03:09 PM
ShanghaiOC's Avatar
Default Re: b20 vtec turbo dyno graph & boost chart
Any thought or feedback is appreciated.
B20 84.5mm
gsr head
arias pistons 9.5:1
eagle rods
acl bearings
arp head studs & rod bolts
750cc rc injectors
hondata s100
Skunk2 tuner 1 cams & cam gears
supertech springs & retainers
mini ram manifold
theShodan's Silver Surfer turbo
si90rex
Engine Management and Tuning
10
May 8, 2013 11:51 AM
ShanghaiOC
Dec 16, 2010 06:02 PM
egboy94
Oct 19, 2010 07:03 PM
turbotypeR@SPEC
Dec 23, 2003 03:11 PM
Ri5e
Sep 8, 2002 06:07 AM
