Tuning Hondata S300, IATs and Honda vs GM for the IAT sensor
What all do I need to monitor on a boosted engine?
Here's what I know I need to keep an eye on:
A/F ratio
oil pressure
water temp
Anything else? IAT, voltage would be nice.
A/F ratio
oil pressure
water temp
Re: Tuning Hondata S300, IATs and Honda vs GM for the IAT sensor
wideband is most important, egt is important if you know how to read it but not nessesary, learning ignition timing is vry important. oil pressure is good to have but not nessesary. engine temps are imprtant, intake temps are important. and if yoru running hondata you have to use a stock intake temp sensor.
Turbo-LS
05-16-2010 05:17 PM
