400hp clearances
Old Nov 30, 2010 | 08:46 AM
mike93eh2's Avatar
Icon6 400hp clearances
just wondering what you 400hp d16 guys are running for rod and main bearing clearances... and also what about ring end gaps?
thanks!
Old Nov 30, 2010 | 03:09 PM
welfarepc's Avatar
Default Re: 400hp clearances
i think RPM plays a bigger role with your bearing clearances.
the ring gaps on the other hand are more closely tied to your power output.
with my D16 i got going right now (which made 450whp on 20psi/pump gas) i went with .022/.024
Old Nov 30, 2010 | 04:24 PM
mike93eh2's Avatar
well most 400hp d16's run about the same rpm....8500rpms
Old Dec 2, 2010 | 03:25 PM
welfarepc's Avatar
depends what turbo you are going to use, i guess... care to share?
i was taking my 6262 D series setup to 9400-9500rpm
Old Dec 2, 2010 | 04:28 PM
mike93eh2's Avatar
it was making power to 9500?
my turbo = precision sc34 bb
Old Dec 3, 2010 | 03:01 PM
welfarepc's Avatar
yeah, flat torque all the way.
dyno plot only goes to 9000 but she pulled just as sweet to 9400. ill be retuning it come this spring.
Old Dec 3, 2010 | 03:20 PM
Rease3's Avatar
danz is the man.
Old Dec 3, 2010 | 04:08 PM
mike93eh2's Avatar
must be your cam... i only made torque to 8500...but i made alot more torque than you..
i made 403whp and 310 ft lbs.
Old Dec 4, 2010 | 03:16 PM
FarmYard's Avatar
that was only on 20psi and 94 oct pump gas though. so props to danz
1sicef9
Jan 10, 2011 06:43 PM
JDM_Risa
Nov 18, 2005 06:50 PM
MrCrx
Nov 23, 2003 04:58 AM
slow02ss camaro
Apr 11, 2003 04:25 PM
