Mass emission mission. What am I missin'?
B18c1 turbo
no cat
no o2's
chipped P28 ECU
The car is technically an OBD2 but ECU converted to OBD1 for tuning purposes.
2 years ago in Massachusetts, there were changes made to all emission checks for inspection stickers. It's ALMOST impossible to get a sticker now if you don't pass emission checks.
Should I just buy a used OBD2 ecu and have it reflashed with my vin#, and then have a local tuner program it to bypass all CEL codes, and tune it on the base map just to get good AFR's for pre-vtec engagement so I can swap computers when inspection time comes? Reason I suggested a minor tune on the OBD2 computer is to complete full drive cycle ~75 miles safely without blowing $#!% up so I can pass.
Would this work?
no cat
no o2's
chipped P28 ECU
Would this work?
Re: Mass emission mission. What am I missin'?
you can't do any of that on a b series obd2. you'll have to swap over stock injectors + ecu. if you could tune an obd2 b/d series ecu everyone would have used i already.
I see. I thought they could be tuned on a base map but not chipped for anything.
Thanks.
Thanks.
I am in no way experienced with tuning. I can pretty much only tell you what AFR's are. Again, forgive my noobishness.
I would need an OBD2 ecu with a reflash with my vin# first.
Then what you are basically saying is I could plug in this AEM F/IC and spend 2 or 3 hours tuning the car, bypassing whatever codes, and I'm done? I can just unplug it and have a permanent tune on my OBD2 ECU without having it reset if I unplug the battery? And this would be a viable replacement for an OBD1 Crome chipped ECU?
What kind of $$$ are we talking to complete this process of going back to OBD2? Full tune and everything
no you wont be able to get rid of codes (you will need to hookup all the proper sensors)...even if you could get rid of the codes the ecu still has to pass all the readiness tests to pass smog...honda should be able to reflash your vin in the ecu.
The options out there for actual tuning and programming of the obd2 honda ecu's are very expensive.
the aem fic is a piggy back for tuning timing and fuel among other things. (no its nothing like a shitty vafc)
My 1996 accord's obd2 ecu did have the VIN programmed in. To pass inspection, I had to do the usual: rear o2 defouler, swap the injectors to stock, pull the wastegate spring.
How did you tune without a front o2 sensor? All open loop maps?
How are people tuning obd2 ecu's now?
Did a little more research on this.
So it looks like without spending upwards of $2-$3k for parts and a tune, there is absolutely no way I will pass mass inspection.
Hopefully the RMV will approve my emission pass request letter. Right now that's looking like my only option.
So glad I'm converting body kit and exhaust back to stock... maybe I can just get away without having a sticker when my car finally stops drawing negative police attention.
just put the stock ECU, injectors, map sensor and o2 sensor's in the car. get it inspected and then switch back. thats what at least half of turbo hondas owners do.
the VIN in the ecu doesnt mean anything, just say your ECU fried and you got another from a junkyard.
However, wouldn't the stock setup read incredibly high emission numbers, since I don't have a cat, thus throwing a CEL? Am I asking redundantly stupid questions here or should I just try it out and see results for myself?
find a buddy take his inspection sticker and give him 25bucks for a new inspection. did this a couple of times with my big turbo 1.8t golf. make sure you get the sticker nice and worm before you start taking it off.
Your engine will be fine if your putting the stock injectors, stock ecu back in, and pull the wastegate spring...unless your engine is built (i'm doubting it is though). You'll have to drive it like 50 miles first before you go for the inspection.
Search for the "defouler trick" and do that to solve your o2 problem.
All this worked for my 1996 turbo accord which was also catless. Just do it.
Its been a whille sense i ive lived in MASS but do they still have the vin # on the stickers tho.
i know it is a pain in the *** big time for any mod to pass goodluck
