vacuum diagram
hello, i recently bought a vacuum block so i want to reroute my vacuum hoses to that one but i have problem which one goes there. Currently my setup goes as follow..
I have a greddy profecb boost controller so in the valve there are 2 nipples. One says in and one out. In the in nipple i see connected one hose from the wastegate, one from a port welded on my intercooler tube(The one that goes from the intake manifold to intercooler).
On the out nipple i see another tube going to wastegate(wastegate has 2 outputs).
I also have a mapsensor for my apexi PowerFC which was connected together with the pressure regulator to one nipple coming out of the intake manifold(golden eagle).
Also, one hose goes from the blowoff to a T join together with the vacuum hose of my boost gauge all together connected with T joins to the intake manifold vaccuum output.
So its a bit mess with all those T joins, i now have a vacuum block, can someone do a proper reroute for all these? thanks
You can put all your hoses to the vacumm block (MAP, BLOW OFF, FUEL REGULATOR, BOOST GAUGE and GREDDY BRAIN).
The IN port on the solenoid is for the turbo source (compressor) and the OUT port is for the LOWER port on the wastegate. The UPPER port on the wastegate is unused.
i use this wastegate
You are saying that the one on the bottom(RED PART) should go to the OUT port of the boost controller valve. What about the IN? I dont see any vacuum hose coming out of my turbo. the only i can see its a vacuum coming out of one of my intercooler tubes(the tube that my blowoff is attached to).
another question..from the brake booster there is a hose that goes to the intake manifold...i used a T join to go aswell to the vacuum block...I really have to have a hose going to the intake manifold?
gnccracer18
Mar 24, 2008 06:14 PM
