DSM 450's on a 98 civic?
getting ready to wire my injectors in and just read over the nice tech article Jeff Frank wrote up
Now I was wondering if my factory 98 civic plugs will only require that little keyway to be removed
some friends of mine seem to think that writeup applies only to 92-95 civics and that I am going to need some clips
Re: DSM 450's on a 98 civic? (Civicman86)
i used my stock clips on my 92
you can notch out the inside of the injector there isa little tab
i did that and mine work great
Re: (thermal)
Even if you can file the injectors or plugs to fit (which isn't possible on a 98), it's not a good idea. When you do that, the plugs no longer "snap" into place.
If one of these plugs ever rattles loose, you could blow your motor. Not worth it IMO, just get new plugs.
Re: (Timmay)
obd2 will need clips or the little conversion harnesses i was telling you about before when you were asking about the rc injectors. pretty much the same idea with any commonly used injectors for honda
Re: (dpetro1)
Forget filing.
Heat up a coat hanger (wear gloves dumbasses) and melt that tab inside the injector off. I did this for my DSM's on my 97 civ.
Ran just fine for years. Its still snaps into place cause of the metal clip on the outside. The tab is just a guide.
Re: (mike1114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 »</TD></TR><TR><TD CLASS="quote">Forget filing.
Ran just fine for years. Its still snaps into place cause of the metal clip on the outside. The tab is just a guide.</TD></TR></TABLE>
You cannot change the clips in any way on 96+ civic to fit dsm injectors. OBD II clips are way different.
If you have a 92-95 you can modify the clips as the car is obd I.
Lets stop spreading wrong info, it put me in a bind when I was doing my install for the first time.
Also I agree, new clips are easy to get and cheap to boot!
Re: (dpetro1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 »</TD></TR><TR><TD CLASS="quote">94-95 tegs are obd1 so no clips are needed. dsms will plug into the stock wiring </TD></TR></TABLE>
after you shave the tab on the inside of the injector
Re: (Timmay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay »</TD></TR><TR><TD CLASS="quote">
after you shave the tab on the inside of the injector</TD></TR></TABLE>
opps totally forgot that. good call.
Re: (dpetro1)
very true, get obd1 injector clips and shave that tab off in the inside center of the injector and your good to go
Re: (7k rdlne)
i have obd0 Clips...i used it on my 450's...but i changed my setup for a set of RC550s...there for sale...10.00 for the clips...LMK
