SC34 .63 ar 57 trim, will the t3/t4 oil lines from stealthmode fit?
like it says SC34 .63 ar 57 trim, will the t3/t4 oil lines from stealthmode fit?
thanks in advance.
thanks in advance.
Re: SC34 .63 ar 57 trim, will the t3/t4 oil lines from stealthmode fit? (dpetro1)
i know its a t3/t4 i was just wondering because i wanted to make sure that the turbo didnt have a different size drain flange or the hole for the feed wasnt different on this turbo.
Re: SC34 .63 ar 57 trim, will the t3/t4 oil lines from stealthmode fit? (B16Civic93)
well i have this turbo and know for sure the inlet is 1/8npt. if you want to double check the drain just measue the bolt holes from center to center, should be 50.8mm = 2"
i dont have the turbo yet i'm getting the lines but i know i'm going to get this turbo and i want to know for sure that the lines will fit before i buy them
bump to make sure
bump to make sure
b16ajdmrex
05-22-2012 06:44 PM
biada1
11-28-2006 12:53 PM
