h22a4 type s
Old Nov 7, 2005 | 04:18 PM
nitroeg's Avatar
Default h22a4 type s
hey guys would a h22a4 with type s pistons handle a te04h turbo if it does how much psi or go with nitrous wet system
Old Nov 7, 2005 | 05:47 PM
SFWD 1934's Avatar
Default Re: h22a4 type s (nitroeg)
Need a little more info on the set up. Type S bump it to 10.5:1 with the stock style headgasket if I am not mistaken. The ringlands on the H22 motors are probably the weakest link in the "stock" set-up. So I would go with like a T3/T4 maybe 57trim. Something that will have a quick spool time, and that will work in the lower boost pressures good. A stock H22 doesn't rev out as high as a B series so you won't start to run out of breath on the top end too much. I would say 7-9 PSI which would put you somewhere in the neighborhood of 240-260 WHP.
The nitrous system will obviously be cheaper and easier from the stand point of labor. Regardless both have to be tuned, and both need/should have a way of adjusting timing when in boost or nitrous is activated.
Good luck. Concord huh, my back yard.
Jason
Old Nov 7, 2005 | 08:55 PM
nitroeg's Avatar
are you sure i thought type s would bump to 11:0.1 comp
Rywen
May 1, 2017 09:17 AM
hondaryda2004
Feb 10, 2012 12:30 PM
cadeMFjohnson
Sep 12, 2010 08:56 AM
track_assassin
Jan 28, 2007 06:53 PM
