need trubo help
Old Nov 5, 2005 | 12:25 PM
plink's Avatar
Default need trubo help
i have a full race kit butt no turbo. im rung a gsr bottum end with pistons and rods b16 head no work in a 92-95 hatch. im looking for 350whp and to be quick light to light. im looking at t3-t4 57 trim or a SC-4431E.
Old Nov 5, 2005 | 12:31 PM
The Weather Man's Avatar
get an sc61. That won't be too bad. Stop street racing by the way. Quick acceleration is okay, but remember speed limits are there for our safety. And yours of course . Anyway, head work isn't necessary to achieve that horsepower level. Forged pistons and rods are a plus, a good manifold, and turbo are better. You can easily acheive that goal. Easily.
Old Nov 7, 2005 | 03:27 PM
plink's Avatar
Default Re: (TheKingPin)
im not a big street racer butt more of a 1/8 miler
Old Nov 7, 2005 | 04:09 PM
yeah me too. Anyway, I say get an sc61. Or a t3/t4 60 trim .63 a/r. They will most definately provide you with the necessary power. Its a b16 head so it flows quite well. I'm using it for my prelude build.
Old Nov 7, 2005 | 05:00 PM
Importordomestic's Avatar
an sc61 is to big of a turbo for his power range..... yeah he can hit 350 on probably 7psi but the turbo is by no means in its efficiency range at that point. why put a 500 + hp turbo on a engine that isnt built for it.
But if you plan to go BIG in the future the sc61 is a good shoice for power up top.
the garrett t3/t4 .60/.62 is capable of 400 horses around 12-16 psi well within its efficiency range. wit hpretty decent spool.
Old Nov 7, 2005 | 05:32 PM
notanotherSC61's Avatar
Default Re: (Importordomestic)
Once again I recomend the sc61. WHY????
Why would you use this turbo on a stock motor and this power range. You MIGHT get power up top but your torque will suffer significantly. THis is not the right application for this setup, If you decide to go this way you will be dissapointed.
Old Nov 7, 2005 | 06:20 PM
TheShodan's Avatar
Moderator
Default Re: (notanotherSC61)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notanotherSC61 &raquo;</TD></TR><TR><TD CLASS="quote">Once again I recomend the sc61. WHY????
Why would you use this turbo on a stock motor and this power range. You MIGHT get power up top but your torque will suffer significantly. THis is not the right application for this setup, If you decide to go this way you will be dissapointed. </TD></TR></TABLE>
I have to totally agree with this. I'm very tired of the SC61 just being blurted out as an answer without understanding HOW he wants the 300whp that he needs, or is looking for. Yes. it is a powerful turbo, but it's not needed for everyone. If he is considering the SC44, due to its characteristics, please contact me. Perhaps you can use another alternative.
Old Nov 7, 2005 | 07:00 PM
plink's Avatar
Default Re: need trubo help (plink)
i will also be runing e boots on neptune i want to go big later butt by that time it will be gt35
Old Nov 8, 2005 | 06:17 PM
plink's Avatar
bump
Old Nov 14, 2005 | 08:26 PM
plink's Avatar
bump need help
Old Nov 14, 2005 | 08:46 PM
TURBOELEMENTS IKE's Avatar
why not a t3/t61? or a t3/t67 or a gt4088 or a gt42r since it seems like bigger is better. but really you may not need a turbo that big just get one that has good overall efficiency and a good solid boost controller and turn the boost up.
Old Nov 15, 2005 | 03:41 AM
WHY CHOSE THE SC61 IN THIS CASE...........
Reason: Because - I'm assuming that he has a non-sleeved bottom end. If he were to get some small *** turbo; he'd have to boost more than 7-8 psi. With an sc61 - he'll be able to reach 350whp very quick, and still have room for more. Whats the point of getting a small *** turbo, when there's a limit? Boost is very addicting - as you all well know - so, eventually, he's going to want to do more bottom end work so he can turn up the boost. This way, he can avoid purchasing a bigger turbo - it will serve both purposes. I didn't only recommend the sc61 - i also recommended a Garrett t3/t4e 60 trim .63 a/r. Thats a nice size turbo for him, and I wouldn't see any reason to go smaller. And if he wants - he can get that turbo w/the ball bearing upgrade for 799.00 + 7.50 shipping.
brandynEG
Feb 23, 2014 09:42 PM
SiKid86
Sep 14, 2006 08:57 AM
EJ8 GSR-T
Mar 19, 2006 05:12 PM
1hot4dr
Feb 15, 2006 05:27 PM
Vtak
Feb 6, 2005 02:25 PM
