New setup after blown motor
Hey everyone I just wanted to post pics of my new engine build. I am not to be credited for the work. I am merely the owner. Rob from TPR cincinatti is the guy with the wrench. Enjoy and thx.
97 Civic Coupe B16a 2.0 Turbo Build est.450hp
ERL Superdeck B16a w/ Deck plate giving the block additional deck height
Engine Specs
TPR Built & Assembled
Balanced Rotating Assembly
ACL Race Bearings (Calico Coated)
Eagle Rods (unfortunatly)
CP 9.7.1 Pistons 84mm
Darton Sleeves
B18B1 Micropolished Crankshaft
ERL 5 Main Girdle
ARP Main Studs
Fuel System
BDL Fuel Rail
Walboro Fuel Pump 255lph (hp)
RC 750cc injectors
Vortec fmu (Going bye-bye)
Engine Management
Hondata S300
Virgin p28 (was)
GM 3 Bar Map Sensor
Timing Belt
GReddy High Power (Blue)
Gauges
DEFI Boost
DEFI Oil Pressure
Oil System
Moroso Oil Pan 6qt
Moroso Oil Pump Strainer
Type R // GSR Oil Pump
Turbo Kit
TPR Stg 2 Kit
ERL T3 Manifold
Tial 38mm Wastegate
Turbonetics MBC
TPR Intercooler 24x12x3
HKS SSQV Blow off valve
Drag Intercooler Piping (Type R)
TPR Oil Feed -3
TPR Oil Drain -10
Turbonetics t3/t4 turbocharger (not shelf)
TPR 5 bolt Downpipe
Suspension
Skunk2 Pro Series Coilovers
Wheels
Rota Circuit 8 Bronze
Modified by tuoniz at 10:04 PM 11/9/2005
Engine Specs
Darton Sleeves
ERL 5 Main Girdle
ARP Main Studs
Fuel System
BDL Fuel Rail
RC 750cc injectors
Engine Management
Hondata S300
Virgin p28 (was)
GM 3 Bar Map Sensor
Timing Belt
Gauges
DEFI Boost
DEFI Oil Pressure
Oil System
Moroso Oil Pan 6qt
Turbo Kit
TPR Stg 2 Kit
ERL T3 Manifold
Tial 38mm Wastegate
Turbonetics MBC
TPR Oil Feed -3
TPR Oil Drain -10
TPR 5 bolt Downpipe
Suspension
Wheels
from personal experience, you WILL burn a hole in your oil return. i had mine the same way, it lasted the summer but eventually it will burn through.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">from personal experience, you WILL burn a hole in your oil return. i had mine the same way, it lasted the summer but eventually it will burn through.</TD></TR></TABLE>
what were you suing for a return line? DRAG kits run the exact same way, and they last for years!?!?!?!
looks good, you trying to retain AC, and PS, and those nice things?
when i had my drag kit w/o the moroso pan, it was never near the d.p. infact all the drag kits i have installed, have had a straight drop. but when i went to the moroso pan, i had my oil return like yours and it did burn through it. i am just speaking from experience. thats all.
yo man...with so much work in building that bitch...shoot for some serious power!!!!
looks like she can handle some serious power, or moderate power levels with serious ABUSE!!!!
that looks like my engine's twin. I will have to post pics soon, as ERL will be complete with my engine assemble this week
nice, i have SAME manifold, as ERL is like 20 min away. we are a dealer and thought id give one a shot. i have to SHAVE THE HELL out of my block tho, off you didnt have to do so much as we have same turbo basically in size, hrmmm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Este_Cara »</TD></TR><TR><TD CLASS="quote">wow..nice setup....</TD></TR></TABLE>
Thx
Thx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ArinX »</TD></TR><TR><TD CLASS="quote">nice pics man
As soon as I download the other pics and vid i got today from my cam i'll upload those as well. Thx
</TD></TR></TABLE>As soon as I download the other pics and vid i got today from my cam i'll upload those as well. Thx
