t04e help
Old Nov 6, 2005 | 04:04 PM
be8teensee1's Avatar
Default t04e help
i just got a t04e a/r 51 for free and was wondering a couple of thing's since this will be my first turbo build ..is this a good turbo for a b18c1 ? will it make good power? and also where it connects to the manifold it has 2 holes not 1 i think it's v-band ..is this better? any answer would be great thanks
Old Nov 6, 2005 | 04:08 PM
Default Re: t04e help (be8teensee1)
come on some one has to no
Old Nov 6, 2005 | 04:11 PM
b16sedan's Avatar
There is no such thing as a "a/r .51" TO4E turbo. We have no ideas of the wheels that are in this, so we can't tell you anything. And you didn't give a great description of this at all, so help us so we can help you. It's like saying "Hey, I got these white shoes and they have laces, how comfortable are they going to be on my feet and what brand are they?"
Old Nov 6, 2005 | 04:14 PM
ok well maybe i got a rare misprint and i can sue garret lol .because it say's it right on the turbo
Old Nov 6, 2005 | 04:24 PM
BlueShadow's Avatar
What kind of car did this come off of? can you take some measurements of it? I was thinking it might be a Garrett T51, but your post wasn't descriptive enough. I'm gonna see if I can find a pic of a T51.
take measurements of the following if you can:
compressor inlet, compressor outlet, turbine inlet and turbine outlet.
Old Nov 6, 2005 | 04:30 PM
Default Re: t04e help (BlueShadow)
dont no what car it came off of but my dad was going to use it for his vw bug but went a differnt way so now its mine ill try to get some pics ..**** my bad it say's a/r 50 m11 oops
Old Nov 6, 2005 | 04:37 PM
BlueShadow's Avatar
Is this turbo out of a car that came from the factory with this turbo? Most Garrett T04E's are stamped M24 on the compressor housing. The only M11 markings I see for Garretts are T3's and I think some T25's. Try contactiong TheShodan, maybe he knows.
Old Nov 6, 2005 | 04:58 PM
cant tell you what car its off of it came from a swap meet ..the exhaust has no flang its just a circle that gets clamped, the fins on the filter side have two sets one sort of sunk behind the other and theres 12 of them ,11 on the exhaust side , it has a four bolt flange but with 2 inlets i read that it helps the turbo spool
Old Nov 6, 2005 | 05:18 PM
BlueShadow's Avatar
dont think that's a T04E you have. It might be a Garrett T25 50 trim or maybe a T3 50 trim. It also sounds like you have a divided turbine housing. A T04E compressor housing has a 3" inlet and 2" outlet. Does your turbo have an internal wastegate?
Does your turbo look like this
http://store1.yimg.com/I/cheapturbo_1870_1259946
Or does it look like this
http://store1.yimg.com/I/cheapturbo_1868_1220565
http://store1.yimg.com/I/cheapturbo_1868_744210
Old Nov 6, 2005 | 05:27 PM
it says on the tag (p/n-1809758c91) (s/n-pfo164) to4e13
Old Nov 6, 2005 | 05:28 PM
and it looks like the first pic
Old Nov 6, 2005 | 05:30 PM
3 inch inlet and 3 inch outlet
Old Nov 6, 2005 | 05:42 PM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by be8teensee1 &raquo;</TD></TR><TR><TD CLASS="quote">it says on the tag (p/n-1809758c91) (s/n-pfo164) to4e13</TD></TR></TABLE>
yah, that info might have helped earlier. Does it look like any of the turbos in the first link below? it sounds like it might be a diesel turbo. According to the second link I posted it is out of a Navistar. The p/n dont quite match up, but they are close.
http://www.qualitydiscountturb....html#
press CTRL-F and type in t04e13
http://www.powertechnologies-t....html
Old Nov 6, 2005 | 05:48 PM
if its a diesel turbo can it still be used
Old Nov 6, 2005 | 05:57 PM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by be8teensee1 &raquo;</TD></TR><TR><TD CLASS="quote">if its a diesel turbo can it still be used </TD></TR></TABLE>
You'd have to find out the specs on the turbos. Send TheShodan an IM and see if he can help you find the compressor and turbine fan specs on that turbo. Either that or contact the people at qualitydiscountturbochargers and see if they can help. your last option is to remove the compressor cover and turbine housing and take measerements of the compressor and turbine fan diameters and post them on here so we can compare it to other compressor fans.
measure the compressor wheel exducer, inducer as well as the turbine wheel exducer and inducer.
Old Nov 6, 2005 | 06:58 PM
wantboost's Avatar
Who is Mr Robot?
if the inlet appears to be v-band with 2 inlets its from a ford navistar/powerstoke engine... the nice part is that those turbos are gt technology... something like a gt40r. garrett used diesels as the testbed for the first gt series lineup... its a little big for a stock b18c1 as the ar is around 1.10 or so ( i know this because i build diesels)
Old Nov 6, 2005 | 07:09 PM
Default Re: t04e help (wantboost)
well i was planning on building the motor for turbo so it wont be stock would this turbo make decent power
Old Nov 6, 2005 | 07:14 PM
wantboost's Avatar
Who is Mr Robot?
yea... lots of power... the turbo on a diesel is rated to 350-400 because of the airflow it requires... on a gasoline motor, its good to over 800
Old Nov 6, 2005 | 07:18 PM
Old Nov 6, 2005 | 07:25 PM
wantboost's Avatar
Who is Mr Robot?
its gonna be really laggy though. fully boost around 6-7 or so
EG95D15VTEC
Jul 20, 2007 01:59 PM
cbrodac0424
Jul 28, 2004 09:20 PM
