Using oversize bore headgasket?!?!
Old Nov 6, 2005 | 10:08 PM
turbotime's Avatar
Default Using oversize bore headgasket?!?!
Ok I have an 81mm bore block and apparently ive been running an 82.55mm headgasket (copper).
So is it normal to run a HG thats larger than your actual bore?? I need to find a new copper HG and i cant find any 81mm bore but the previous kind i used was 82.55mm bore and im wondering if i should just use that or if thats why the gasket blew so soon....
Can I use an overbore headgasket, if so what the highest overbore i could go? I want to use an SCE Pro Titan Copper but its like 84mm or larger...
Old Nov 6, 2005 | 10:29 PM
HYBRID_H@TCH's Avatar
Default Re: Using oversize bore headgasket?!?! (turbotime)
if you contact sce they can custom make one in any bore size you like..
other than that I belive the stock OEM honda HG is 81.5mm stock..
Old Nov 6, 2005 | 10:51 PM
airshifter's Avatar
over bore gasket will just lower your compression a tiny bit, why are you running a copper gasket, use a stock one
Old Nov 6, 2005 | 11:24 PM
turbotime's Avatar
i have SS orings machined into my head, I HAVE to use a copper headgasket...
I will contact SCE thanks .. stock b17a1 bore is 81.55, not 81mm?
Im calling flatout omorrow so ill call SCE as well... the old gasket was SCE but it was definitely overbore...
Old Nov 7, 2005 | 04:20 AM
turbotime's Avatar
up
f1 vtec
Jul 15, 2020 02:47 PM
Honda_Tech01
Jun 23, 2008 08:42 AM
btech
Sep 2, 2006 09:08 AM
ITRNoah
Apr 22, 2004 09:21 AM
1badITR
Jan 22, 2003 09:38 PM
