need some help on 2000 integra ls turbo?
i live in ny where emission testing is close to cali.
so to all of u guys out there
i would like to slap a greddy kit on my 2000 integra ls and run the set psi for that which i think is 7-8 psi
what do i need to do after i bolt on the system .
what do i do with the ecu and how do i go about driving the car to the dyno
i need to keep the car obd 2 because of ny is there a way to run this kit with my car and not get any engine lights?
im sure someone out there has done this.
i am not looking to make a race car just a fun dd to ride
thanks for all your input
Re: need some help on 2000 integra ls turbo? (tegrunner)
have you thought about using the vafc hack setup? if u want to keep your stock obd2 ecu thats maybe what you have to 2 do
Mr. Badwrench
it depends if they do a sniff test and or a readiness test.
in delaware they do a readiness test on obd2 cars. if thats the case the blue box with the kit will suit you fine, BUT if they sniff, the blue box is a little too fat for the sniffer test.
Re: need some help on 2000 integra ls turbo? (boostedcivicsir)
i believe they sniff here they just started doing it
i dont truly understand everything
the blue box that comes with the greddy kit is what the dyno tunners use to tune correct and then i just simply plug that blue box into my ecu. correct.
so when i unplug that blue box wont my car run at idle ok just to do the test and then i can plug the blue box back in.
