HELP: what size is the oil drain flange on my precision sc61
i need to buy the flange but i dont know what size it is, is it 38mm,44mm,50mm??????????????????????
Mr. Badwrench
Re: HELP: what size is the oil drain flange on my precision sc61 (98TEG2NV)
are you talking about the threaded part of the oil return flange? if so it is usually 1/2 pipe thread.
is this it?
is this it?
Re: HELP: what size is the oil drain flange on my precision sc61 (project dc2)
are oil drain flanges the same size for both t3 and t4 turbos. not the threads but the actual bolt pattern and dimensions to the turbo? i know the t25 has a different style which made me wonder.
Re: HELP: what size is the oil drain flange on my precision sc61 (dpetro1)
Take the turbo and measure the drain flange mounting bolt holes from center to center in MM.
T3, T3/T4 drain flange 50.8mm
T25 drain flange 44mm
14B drain flange 38mm
(some other turbo's share these sizes)
Re: HELP: what size is the oil drain flange on my precision sc61 (stealthmode62)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthmode62 »</TD></TR><TR><TD CLASS="quote"> Take the turbo and measure the drain flange mounting bolt holes from center to center in MM.
what about straight t4
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 »</TD></TR><TR><TD CLASS="quote">what about straight t4</TD></TR></TABLE>
Same.
Same.
You need this one:
Buy it here: http://cgi.ebay.com/ebaymotors...25681
Also have this kind, if you prefer to use your own NPT to AN fitting:
http://cgi.ebay.com/ebaymotors...25722
