All motor B20 or force fed turbo B20?!?!?!?!?!
Old 11-04-2005, 03:02 PM
H22a1civic's Avatar
Default All motor B20 or force fed turbo B20?!?!?!?!?!
A friend wants to know if he should just drop a B16 head with grs cams and build his way up from there. Or if he should go B20 turbo non-Vtec??? This will be in his daily eG Hatch!
Let me know what you guys think.....
Old 11-04-2005, 03:32 PM
JalopySiR's Avatar
Default Re: All motor B20 or force fed turbo B20?!?!?!?!?! (H22a1civic)
I think I might know what most people in this forum are going to say.
I would agree.
Turbo it.
You'll hear about the weak sleeves, but as long as you're careful, you'll be fine.
Old 11-04-2005, 07:44 PM
Who is Mr Robot?
wantboost's Avatar
how about put the b16 head on the b20 block then boost it.... duh
Old 11-04-2005, 07:46 PM
Blackack26's Avatar
Default Re: All motor B20 or force fed turbo B20?!?!?!?!?! (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">how about put the b16 head on the b20 block then boost it.... duh</TD></TR></TABLE>
haha I like the way you think!
Old 11-05-2005, 11:21 AM
H22a1civic's Avatar
For one its not my ride!
Two, I dont know **** about B20's, I have only worked on all-motor H22's!
Three, I am just here for peoples opinions. Not there lil sarcastic remarks!
Old 11-05-2005, 11:40 AM
b16sedan's Avatar
If he builds it all motor he might end up with a car that runs 12s on slicks at like 105 MPH. If he does a turbo setup he can put it deep 12's @ 115+ MPH and be much more fun to drive on the street. Tizzurbo!
Old 11-05-2005, 12:00 PM
Who is Mr Robot?
wantboost's Avatar
first off... i wasnt being sarcastic. if he has access to a b16 head then tell him to go b20/vtec then boost it
Old 11-05-2005, 12:35 PM
SOHC_MShue's Avatar
Why would you post this question in the forced induction forum? I think the answer you will recieve in here is obvious.
Old 11-05-2005, 08:50 PM
H22a1civic's Avatar
Default Re: All motor B20 or force fed turbo B20?!?!?!?!?! (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">Why would you post this question in the forced induction forum? I think the answer you will recieve in here is obvious.</TD></TR></TABLE>
I didnt just post it here. I posted it in the all-motor form as well. I just want to get both side's of opinions on it.
Old 11-05-2005, 10:57 PM
SOHC_MShue's Avatar
Well what are your goals? How much money do you have to spend and how fast do you want to be?
Old 11-06-2005, 04:12 AM
PRELUDE-GT35R's Avatar
Turbo all the way
Old 11-06-2005, 04:31 AM
Brrraaaap!
Blaze45's Avatar
Default Re: All motor B20 or force fed turbo B20?!?!?!?!?! (PRELUDE-GT35R)
15lbs pushed by a T3/T4 57trim 63ar fed to a stock block B20 ownz me everyday. Small turbos kick my butt off the line, then I finally spool, and its over.
Boost for life!!!!
Blaze
Old 11-06-2005, 07:26 AM
areyouasian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">Well what are your goals? How much money do you have to spend and how fast do you want to be?</TD></TR></TABLE>
thats basically what it comes down to, what power level and how fast are you going to be satisified with?
also b20 boost will last if you dont push it too much with the boost. my cousin has a stock b20 thats been boosted for over a year now on about 12 psi (250 hp) daily driven for about 40 - 50 miles per day and it hasn't crapped out on him yet. for the most part, everyone that i see that have their b20's failed on them boosted about 15 psi or more and ragged the **** out of it. i think any stock motor would fail if you did that.
Old 11-12-2005, 01:08 PM
GoCarInteg's Avatar
Default Re: All motor B20 or force fed turbo B20?!?!?!?!?! (Blaze45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">15lbs pushed by a T3/T4 57trim 63ar fed to a stock block B20 ownz me everyday. Small turbos kick my butt off the line, then I finally spool, and its over.
Blaze</TD></TR></TABLE>
block guard or re-sleeved?
Old 11-12-2005, 03:23 PM
Brrraaaap!
Blaze45's Avatar
Default Re: All motor B20 or force fed turbo B20?!?!?!?!?! (GoCarInteg)
Neither, its a stock block B20.
Blaze
Old 11-12-2005, 03:36 PM
vti2's Avatar
Sleeve it and boost it.
Very hard!!!!!!
Drive it with 20PSI on a big turbo.
I can ensure you after your first drive on high boost you will forget your girlfriend very fast
Boost forever
EBEATS
07-28-2008 02:45 PM
ek9ferny
09-26-2007 08:50 AM
teamvirus
13
10-27-2005 11:51 AM
cxhb
05-26-2005 09:14 PM
CRXCrazy123
05-04-2005 08:21 AM
Quick Reply: All motor B20 or force fed turbo B20?!?!?!?!?!
