Over-rev my motor….. Bent Valves?
Hey Guys I recently over-rev my motor & the #4 piston went out!
Now that I got the block Fixed. I assembled the motor Using the same B18C1 Head.
Re-Did the Valve Adjustments Perfectly. OE Specs.
Problem:
Now the car Sounds Like a Truck Motor?? (From the Head)
It doesn’t sound Like a stock Normal (Quiet) Head (like before the over-rev)
It seems like the #3 Intake or Exhaust Valves are not closing completely or functioning Normal because that’s where the Noise is coming from!
Because when I try to rev the motor past 4K it boggs. But when you Partial Throttle You’ll Kinda get by.
What does this problem seem to Be Guys???
Re: Over-rev my motor….. Bent Valves? (spoonhatchblack)
most likely your vavles are bent. i had couple friends do the same thing and had bent vavles. its time to get a BUILT HEAD!
Re: Over-rev my motor….. Bent Valves? (soontobeboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soontobeboost »</TD></TR><TR><TD CLASS="quote">most likely your vavles are bent. i had couple friends do the same thing and had bent vavles. its time to get a BUILT HEAD! </TD></TR></TABLE>
that sucks.
what is the easiest way to check for bent valves when the head is out?
that sucks.
hrs-parker
10-01-2008 06:06 AM
ivan93egreppin210
04-14-2008 08:15 AM
spoonhatchblack
11-06-2005 09:38 PM
spoonhatchblack
11-06-2005 11:09 AM
Turbo R
04-26-2005 09:56 AM
