Will running closed loop has significantly better mpg?
GSR motor. My open loop partial throttle is tuned fairly well 14.7-13.5 AFR. And yet my mpg is 21 highway and 18 city. I only do WOT pull probably 3-4 times a week
I troubleshoot everything you can think of:
ultrasonic cleaned and tested injectors, new distributor cap, rotor, blaster ss coil, new sparklug and ignition wire, fuel filter, air filter, etc.
I wonder whether I should go closed loop on my uberdata.
BTW, my partial throttle is between 15 and 16:1, but sounds like something else is going wrong with your setup. I do WOT pulls pretty much everytime I drive my car and never get below 30 mpg.
Re: (elpiar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elpiar »</TD></TR><TR><TD CLASS="quote">Your motor is SOHC? D16?
isn't 15 to 16 is a little lean even for partial throttle?</TD></TR></TABLE>
That doesn't matter. As long as the motor isn't hesitating or lean- misfiring then you can run as lean as you want. Once you start putting load on the engine then you have to have the correct AFRs
Re: (xyrth)
my motor ran like **** at anything leaner than 14.5-15.1. it would pop and hesitate and basically drive shitty. my perfect a/f for driveability was like 13.9-14.5. i still managed 25-28mpg on a 200k mile ls with a gsr trans that i would do wot runs at least every time i drove it, which was probably every other day.
Re: (blackeg)
pretty much any stock closed loop is 14.7:1, it's what narrowband o2's are good at, and, it's easier than making it variable based on load/gear.
as far as what ratio works or doesn't, it differs a suprising amount from motor to motor.
ie: my dsm (8.8:1 2.4L) likes 16.5:1 anytime i'm above 2,000 in 3rd, 4th, or 5th, and above 3,500 in first or second, at less than about 40% throttle. supras seem to be about a half point leaner, i'm sure there are motors that need to be richer, i just never guessed it would be a honda
what kind of wideband are you using?
Re: (xyrth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xyrth »</TD></TR><TR><TD CLASS="quote">pretty much any stock closed loop is 14.7:1, it's what narrowband o2's are good at, and, it's easier than making it variable based on load/gear.
what kind of wideband are you using?</TD></TR></TABLE>
I'm using PLX M250 w/ gauge
I would highly recommend running in closed loop on a street car. Sensor technology was created for this purpose, why fight it?
My car gets 28-32mpg and I drive spiritedly.
Sensor technology was also created for emissions, there is a good reason to fight it if you can. I'd rather run a good bit leaner than 14.7:1 and get mor mileage because I don't really care about the Nox I'm putting out.
Re: (nonvtecD)
i get 22-25mpg...i guess it all lies in tuning...i am running open dumptube i don't think it really matters or does it? i beat on my car everytime i drive it on 10.5psi
street tuned cars will get better gas mileage opposed to a dynotuned car which is only really tuned at WOT so at partial throttle the car is not gettin a good a/f mixture
Re: (JDM_Risa)
My tuner broke in my motor on the dyno. He first set it up to where it runs closed, not sure of A/F, until I hit boost and then it is open loop. I get around 26-29 when I'm not on it, but then when I'm pulling several times a day I notice that I'm getting around 20-22 mpg. B16 @ 11 psi
platinum00
12-12-2006 01:13 PM
TranspeedMotorsports
13
11-23-2006 03:17 PM
