lossing power on turbo setup
Old Nov 7, 2005 | 07:29 AM
Bartman201's Avatar
Default lossing power on turbo setup
ok like it saids on the title im lossing power when i hit the gas all the way. im boosting 9psi. why is this happening any ideas, here is my setup:
B18b
srp pistons 9:1
eagle rods
port & pol head
blockgard
fuel pump
370cc injectors
Chipped ECU
Garrett t3/t4 TB0356 turbo
Greddy IC
XS turbo manifold
turboxs Blow Off Valve Type H
skunk 2 cam gears
turbonetics deltagate
Golden Eagle Vacuum Manifold
Old Nov 7, 2005 | 07:57 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: lossing power on turbo setup (Bartman201)
it needs to be tuned most likely..
Old Nov 7, 2005 | 08:01 AM
boostedcivicsir's Avatar
Mr. Badwrench
have any idea where your AFR is?
is the engine sound? is the compression ok?
Old Nov 7, 2005 | 08:02 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: lossing power on turbo setup (boostedcivicsir)
yea, you could have popped a ringland... does it smoke?
you could be running too rich or you cuold be running too lean
Bartman201's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">have any idea where your AFR is?
is the engine sound? is the compression ok?</TD></TR></TABLE>
compression is fine
Old Nov 7, 2005 | 08:03 AM
Bartman201's Avatar
Default Re: lossing power on turbo setup (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">yea, you could have popped a ringland... does it smoke?
you could be running too rich or you cuold be running too lean</TD></TR></TABLE>
no smoke
Old Nov 7, 2005 | 08:04 AM
Bartman201's Avatar
if i hit the gas half way it has more power that if open at full throttle. i could have a leak in the piping.
how do i check for leaks in the piping?
Old Nov 7, 2005 | 08:34 AM
Bartman201's Avatar
ttt
Old Nov 7, 2005 | 08:37 AM
wantboost's Avatar
Who is Mr Robot?
so you dont have an dmu? that problem sounds typical of an fmu.... now that you said that i know what your problem is.... its running to rich at wot... has it been tuned yet?
Old Nov 7, 2005 | 01:52 PM
Bartman201's Avatar
im running a basemap right now.
Old Nov 7, 2005 | 05:47 PM
LVB18Civic's Avatar
You need to tune it ASAP. I would never drive around on a basemap, they run way too rich.
Old Nov 7, 2005 | 06:19 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: lossing power on turbo setup (LVB18Civic)
thats way.... a basemap runs really really rich.... my first post was get it tuned....
fin781
Jul 29, 2009 06:05 PM
94civicgsr
Feb 10, 2008 09:21 AM
Bartman201
Nov 2, 2005 07:33 PM
Bartman201
Oct 6, 2005 11:09 AM
riceburnah
Nov 22, 2004 12:49 PM
