Hadn't posted an update in a while.
Old Nov 6, 2005 | 12:04 PM
TheShodan's Avatar
Moderator
Default Hadn't posted an update in a while.
Well, thanks to the "Beaver", I starved one of the cam journals and destroyed my head earlier this year. After some time off, a new baffled pan, and some funding, I was finally able to make the head complete.
Here's what I used:
-Supertech Nitrite treated higher compression valves (about .3-.5 static compression increase
-5 angle Valve Job
-Surface of the head milled .015"
-Omnipower bronze valveguides
-New Valve seats
-Type R Cams (Selling the GS-R Cams, PM me if interested, in my sig)
-Toda Valve Springs and Retainers
-Simple clean up of the Intake and exhaust ports. I know this will be a controversial statement, (hell, what do I care) but I found that through bench flow test of many of the GS-R VTEC heads only had an average of a 20cfm increase in flow of the head when it was port & polish as opposed to just a good clean up. that's why I concentrate on the turbo and motor to do its work, and not worry about the increased cost of Pnp'ing the head.
By the time it is all said and done, it's about a 9.8:1 static compression, even with the 9.0:1 pistons, which is great for the road course. And Naturally, OEM Headgasket
Perhaps a few pics to show you..
Here's the car itself..
Modified by TheShodan at 6:02 AM 11/8/2005
Old Nov 6, 2005 | 12:27 PM
rhdune16's Avatar
wow very nice indeed. Those wheels are very nice.... remember me... the accord that almost blew up on the dyno....
Old Nov 6, 2005 | 12:54 PM
adseguy's Avatar
Default Re: (rhdune16)
Nice head setup. How far do you think you will be revving to? Also are you using any cam gears to go along with the setup?
Old Nov 6, 2005 | 12:56 PM
TheShodan's Avatar
Moderator
Wow Rhdune. I do remember that. Did you take care of those problems that we talked about?
Old Nov 6, 2005 | 12:59 PM
TheShodan's Avatar
Moderator
Default Re: (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">Nice head setup. How far do you think you will be revving to? Also are you using any cam gears to go along with the setup?</TD></TR></TABLE>
I'm probably going to about 9000 or so, but only occasionally on some turns, no more than that at all. as for the cam gears, I'm using TODA RACING GEARS.
Old Nov 6, 2005 | 07:48 PM
superi0ro1's Avatar
Default Re: Hadn't posted an update in a while. (TheShodan)
are those the garica tuned edition of the te37???
Old Nov 7, 2005 | 06:06 PM
TheShodan's Avatar
Moderator
Default Re: Hadn't posted an update in a while. (superi0ro1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superi0ro1 &raquo;</TD></TR><TR><TD CLASS="quote">are those the garica tuned edition of the te37???</TD></TR></TABLE>
They were the old Stephen Papadakis "Back in the day" chrome TE37s
Old Nov 7, 2005 | 06:49 PM
andysila's Avatar
wow, very very clean.
baynedo
Mid-Atlantic (Sales)
May 27, 2011 01:55 PM
ek9=]
Sep 22, 2008 05:58 PM
frostyrb
May 17, 2008 08:16 PM
SolLesHonda
Nov 7, 2006 06:05 PM
