Click/Clank noise in reverse?
Old 04-06-2014, 12:21 AM
1988civicwagon's Avatar
Default Click/Clank noise in reverse?
Hi,
I have a 1988 Civic Wagon RT4WD 6 speed manual transmission car. It makes a click/clunk sound when moving in reverse. The sound goes away when the clutch in pressed down, and gets louder/quicker at a higher speed (more gas/more load).
It shifts smoothly into all gears. Runs fine in all the other forward gears. Paper work shows that it has new CV joints within the past two years.
I have changed the transmission fluid with Honda fluid. I have also messed with trying to disengage the 4WD. It did seem to get a bit quieter, but it was on stands and the locking bolt to switch back broke when I tried switching back to the 2WD mode. So it is in 4WD mode now until I am able to figure out how to get the 1/2 bolt out of the transmission housing.
I have looked at the motor mounting brackets by trying to rock/push the motor and could not feel/see any movement.
Does this sound like a transmission issue? If so, any suggestions on what the issue is with the transmission? And would a simple auto store rebuild kit solve the issue?
Any other thoughts?
Old 04-06-2014, 12:29 AM
turbomaniac's Avatar
Default Re: Click/Clank noise in reverse?
have you checked/renew the rear end differential oil?
Old 04-07-2014, 12:02 AM
I have not changed rear end oil.
Old 04-08-2014, 07:27 AM
certainly it is a transmision issue, suppose not from gearbox.
check again all differential and gearbox oils.
differential oils sould be replaced after 60.000 miles. If not, the front and rear end differential could dammage and make strange sounds...
ToledoLude
05-05-2017 06:38 PM
ncpi
Honda CR-V & Element
01-03-2012 12:31 PM
dad0c402
01-26-2007 10:10 AM
redrelease
10
08-15-2006 05:40 PM
MRDC2
09-20-2001 06:42 PM
Quick Reply: Click/Clank noise in reverse?
